FTTC DSLAMs and the flooding
- FTTC DSLAMs and the flooding
10-02-2014 1:09 PM
Seeing as the flooding is getting progressively worse, I have a few questions about the FTTC DSLAMs in flooded areas:
What happens to the DSLAMs in flooded areas?
Are Openreach turning off the power to them?
I am assuming they are IP65, but will the water damage or ruin them?
Message 1 of 2
(538 Views)
1 REPLY 1
Re: FTTC DSLAMs and the flooding
10-02-2014 4:33 PM
I'd doubt they are IP65 much less IP68 for full immersion!
Probably something like IP43 to be secure against full scale thunderstorms and driving rain.
Even if they switch them off I wonder what the ?4? hour UPS backup battery in them is rated to IP wise? - you really would not want that to short out and go bang.
Then you have to account for the point that sewage/contaminated water almost certainly could/will get into them so that's a H&S issue even if it does dry out and mysteriously still work.
I'd hazard a wild guess that a fully/part flooded one is scrap.
Message 2 of 2
(252 Views)
