FTTC Currently Being Installed
- Re: FTTC Currently Being Installed
04-09-2013 5:34 PM
Hi There,
BT Openreach have already installed the Fibre Cabinets and have already connected the Fibre cabinets and broadband cabinets together so I'm wondering what happens next if anyone can give some insight.
Message 1 of 9
(1,365 Views)
8 REPLIES 8
04-09-2013 6:24 PM
Keep putting your telephone number in to http://www.dslchecker.bt.com/adsl/adslchecker.welcome
You could also look at what http://www.superfast-openreach.co.uk/where-and-when/ says.
Message 2 of 9
(682 Views)
17-09-2013 4:41 PM
Hi Jelv,
According to the BT Openreach it should be completed by 31/12/2013.
I was also told by a friend that they could offer fibre optic sooner, hence the reason I was asking if anyone knew what happens next.
I've tried to get an email for Openreach to ask but no luck, and there website isn't helpful, the offer only limited information.
At this point they've connected both cabinets and are now planning minor works between the cabinets and peoples houses on the road.
Message 3 of 9
(682 Views)
17-09-2013 6:55 PM
Just keep checking regularly using the dslchecker link provided by jelv.
The date and status will change if indeed it does become available before the original estimated completion date.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Message 4 of 9
(682 Views)
18-09-2013 10:09 AM
Exactly, my date was always 30th June, but I just checked the BT Checker daily after the fibre cab was installed (end March) and all of a sudden it went to accepting orders early in May and I got an install date for 10 days after that. Engineer told me I was the first person on it in the cab too.
Message 5 of 9
(682 Views)
18-09-2013 1:26 PM
Thanks for the reply and for giving me some hope that I might not have to wait too long ;D, when I check through the dslchecker link it keeps telling me there's no data available for that number, pretty weird.
Message 6 of 9
(682 Views)
18-09-2013 1:57 PM
Odd! That only usually happens when it's a non-BT line (e.g. Sky/TalkTalk)
Message 7 of 9
(682 Views)
18-09-2013 2:10 PM
Unfortunately as you're on a LLU line at the moment you won't be able to see anything using your number until the line transfers to us.
You should be able to use the address checker underneath in the mean time
Message 8 of 9
(682 Views)
22-09-2013 4:34 PM
Yeah at the time I was with Sky, but switched over on Friday, it registers now which is good.
Message 9 of 9
(682 Views)
