FTTC Cabinet Rollout
- FTTC Cabinet Rollout
22-02-2012 11:21 AM
Just wondering if you guys can check scheduled rollouts of FTTC cabs from BT?
The reason I'm asking is my exchange has been enabled for Digital Region for some time, however, there's an issue with installing a fibre cab on my estate. It's a newish build and there's a dispute with the property developers that stopped Thales from installing a new cab.
I'm not sure if they would allow BT to install a new one though as they already have a cab/equipment installed?
My cabinet number is either WIC045 or WIC046 and is against the Wickersley exchange in Rotherham.
Message 1 of 2
(1,017 Views)
1 REPLY 1
Re: FTTC Cabinet Rollout
22-02-2012 12:43 PM
Hi mrbez,
We can't check cabs that haven't been enabled. It looks like it's on the 'to do' list though as if you pop your number into the BT Availability Checker it shows this
[quote=BT Availability Checker]Your cabinet is planned to have WBC FTTC by 30th June 2012. Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 40Mbps and upstream line speed of 10Mbps.
30th June, however, is probably a place holder date which means that although it's planned, there's no confirmed date yet.
Jojo
Jojo
Message 2 of 2
(346 Views)
