FTTC Bi-monthly slowdown
- FTTC Bi-monthly slowdown
22-10-2013 7:03 PM
Re starting the modem and router don't change it and there is no noise on the line. When it happens, new web pages take a long time to start to load, but then are fine.
Anybody got any bright ideas?
Re: FTTC Bi-monthly slowdown
22-10-2013 7:07 PM
BT test added
23-10-2013 9:42 AM
As you've mentioned that upload doesn't seem to be affected and that there's no noise on the line we should be safe to assume that the copper section of the line isn't to blame for the issue.
Interference could be to blame but again as there's no symptoms relating to the copper line it's less likely to be within your premises which makes be thing that this could perhaps be an exchange issue.
I'd advise getting a <a href="http://faults.plus.net">fault</a> raised whilst this is an issue and whilst I don't mean this in a negative way have patience as this is an unusual problem but I do hope we're able to help get that resolved for you.
23-10-2013 9:50 AM
23-10-2013 10:22 AM
W23, I have, it's attached to my second post.
23-10-2013 10:57 AM
23-10-2013 6:56 PM
Latest BT test similar to last one.....
26-10-2013 7:41 PM
27-10-2013 12:52 AM
As yet, I have not had any contact from the Plusnet faults team, the ticket just says being investigated.
Hope something can be sorted out, as the next time will be over the Xmas period........
27-10-2013 6:17 PM
Seems I'm not the only one then. Thanks to RealAleMadrid, I've got in contact with Andrue via TBB forum and he is/was having the same problem.
27-10-2013 9:55 PM
Did you use the whitebox software?
27-10-2013 11:05 PM
27-10-2013 11:54 PM
29-10-2013 9:24 AM
29-10-2013 10:28 AM
If the fault follows its usual path, then it will fix itself by the 1st of November!
