FTP intermittently timing out
ed89
wonder if anyone can shed some light. When uploading some files using FTP it often times out. Even when I'm pushing a file as little as 2kb.
Rebooting the router/connection seems to sort it but after a short while it does it again. Bit of a pain to have to keep disabling/enabling things every time I need to upload a file!
Is there anything I can do?
cheers
ed89
Re: FTP intermittently timing out
still experiencing this problem. Anyone have a possible solution?
cheers,
Ewan
Fixes: 162
Does this happen to multiple FTP servers? Have you tried a different FTP client or does switching betwen active and passive mode make any difference?
 Chris Parr
 Plusnet Staff
Fixes: 18
I used to have this problem, then I found FTP COMMANDER..... download it, then you should be able to drag and drop all your files and they all go in one shot !....
Good Luck  (ps  it`s free)  Smiley Smiley Smiley
Other software for FTP ing is available, have a look here and make your choice !
http://www.thefreesite.com/Free_Software/FTP_freeware/
