FTP Upload = Very Very Slow
abbiati50
experiencing since quite few months - usually from 1 pm to 2 am - - basically the entire lenght of a human being internet life - very bad ftp upload speed and connectivity !
speed from 3/4 kb/sec - somentimes 6 or 7 with CONTINUOS !!! disconnections from ftp due to very weak connection are at the order of the day !
tested with different modems - routers - pc's - and differents ps accounts - without any difference.
very depressing !  Cry
Fixes: 62
Re: FTP Upload = Very Very Slow
Can I ask which server you are trying to upload to and the ftp upload program you are using.
I assume speed tests are fine at the times you have the problem
Can you post your router stats - attenuation, noise margin and speeds - with your problem the upload stats are important.
Finally are you sure that you or another user on your account doesn't have a P2P application running.
abbiati50
hi - tx for bother !
right now i use a THOMSON ST546 - it has an online interface - but could not find the stats
i upload into dedi servers - at the moment im testing with fireftp - and it is a bit better - even if not at its best - it stay connected and reasonably can upload
using filezilla - ws_ftp - smart ftp - - it is a no go -
where i can find the router stats ? - if i can ill post
tx
Fixes: 62
Here http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
Just a point - which product are you on.
abbiati50
hi Oldjim;
thanks for that - bookmarket
it look like this:
Uptime: 0 days, 1:10:28
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Data Transferred (Sent/Received) [KB/KB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 16.0 / 27.0
SN Margin (Up/Down) [dB]: 23.0 / 6.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 142
CRC Errors (Up/Down): 0 / 3
HEC Errors (Up/Down): 0 / 3
im on the plus unlimited product
tx
ray
abbiati50
is midnight and the ftp start to go like a rocket ! - that is for sure about throttling of service ! as it a regular thing everyday.
spot the difference !!
Uptime: 0 days, 2:37:44
SN Margin (Up/Down) [dB]: 23.0 / 6.5
FEC Errors (Up/Down): 0 / 234
Fixes: 62
You missed the other question - which product are you on
EDIT - must get new glasses  Embarrassed Embarrassed
James
No he didn't.
He said that he was on Unlimited.
@Abbiati50
http://www.plus.net/support/broadband/quality_broadband/speed.shtml#unlimitedspeeds
Your external FTP speeds will drop as low as 164Kbps during peak times of the day.
scootie
the thread title is upload. so there shouldnt be any rate limit applyed on unlimited
James
Good point - thanks.
I'd be interested to know if there's any other internet activity going on at the same time, which could impact upload speed.
Fixes: 62
James,
Is it possible to check the profile the OP is on.
I ask because what is being described is what would be expected from a BBYW product
James
Can be done, but we'd a ticket to be raised so that we can get networks to investigate it.
abbiati50
good evening !  Cheesy
thanks for bother about this issue !
to clarify the all story :
the problem occur between 12  (midday)  and 2 am
the problem is : upload ftp it is very very slow with many disconections
no other user use same account : this is my unlimited account - and also i do not use any p2p while uploading into the servers
i do not consider hardware fault or pc faults - simply becouse if i use the ftp between 2 am to about 12 midday  - it work OK ! the speed is normal
tx
ray
abbiati50
ok thanks - the table explain !
but let me say - often during the day external ftp speed is much lower than what the table show - around 100 kbps - 80  or so
this evening is good speed - - - - but yesterday evening at the same time i had nearly no speed at all !
Fixes: 62
It would be a good idea to raise a ticket as James suggests asking for a check on your profile as you are seeing very poor upload FTP speeds. Emphasize it is upload speeds and ask networks to check.
This is the link to start raising a ticket http://www.plus.net/wizard/index.html?supporta=helpnotice then click on Technical Support then click on Ask a Question (Raise a Ticket) as shown below
