FAO Wiresharkers - Wiresharking help wanted
Plusnet Staff
Plusnet Staff
Hi all,
I'm crossing my fingers that iPlayer is fixed now, so assuming we don't see any more problems, I'm thinking it's time to move on and ensure we are correctly tagging the other UK broadcasters streaming TV services. So I'm planning on starting off with SkyPlayer with them showing the cricket live online it makes a good time to ensure it's right.
So I'm looking for a few people to do me a bit of testing please, if you have Sky can you run me a couple of wireshark captures of SkyPlayer's live TV stream. Just need a capture of the first few seconds of the video but make sure you start the capture before starting to play the stream.
Next on the list will be ITVPlayer so any captures of that would also be useful.
Fixes: 154
Re: FAO Wiresharkers - Wiresharking help wanted
If PN will fund Sky for me I'd be delighted Roll eyes Grin
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Plusnet Staff
Plusnet Staff
Sadly can't do that, but an ITVPlayer capture will do instead Smiley
Fixes: 154
OK I'll see what I can do...
Plusnet Staff
Plusnet Staff
Nice one, ta.
Fixes: 154
Where do you want them?
Plusnet Staff
Plusnet Staff
Thanks, for the benefit of anyone else not on IRC, if anyone else runs any captures can you email them to me at dtomlinson@plus.net and I'll see if they match the sigs I've got so far.
This might give me an excuse to give that new Charlie Brooker programme a go on 4oD. Though I really need to work on my portfolio so I'm not sure I'll do it any time soon. Sad
scootie
i might give it a try. but first whats wireshark? Grin
wen sky players relesed on the xbox i rekon that might be hard one for you to get right
Plusnet Alumni (retired) _CN_
we got the others for you Asbo (in the end :-) )
Tsonga
Just emailed you a capture from ITVPlayer. We don't have Sky!  Smiley
Tsonga
Quote from: dave
Aaaargh, silly me, did not do that! Will try a better one soon! Sorry!  Embarrassed
Plusnet Staff
Plusnet Staff
No worries, in most cases to create a signature for a particular application we need the beginning of the flow of the traffic (not all, sometimes you'll find it gets matched further along in the stream). The first few packets will contain an exchange of information about what the application is or certain "key" pieces of information (as well as the port and source IP address) that we use to match the traffic. So with something like a video stream the match actually needs to be done at the start of the stream rather than further down otherwise if it's marking it as unknown at the start the video might start stuttering to begin with.
ITVPlayer and SkyPlayer sigs are now live though and getting hits, ITV peaked at 25Mbps between 10pm and 11pm last night, Sky did about 150Mbps around midday yesterday. If you're using one of these apps your usage should now show up as Streaming in VMBU, previously would've been Web.
Next on my list is 4oD and from there anyone else have suggestions for streaming apps?
scootie
i would of said tvcatchup.com but there having trouble with new desktop player and took it off line so its only the old webplayer at the moment. but am sure wen they first relesed the desktop player we made sure it was picked up right and it was but when they start bringing the new web player and desktop app back online again i will keep my sharks eye on them
Quote from: dave
There's also 5's catchup service - http://www.five.tv.
