Extremely slow speeds - possible filter/socket issue
zenislev
I've been experiencing very slow broadband speeds over the last few days. I suspected a faulty filter due to an uncanceled echo (see below) but replaced it and the issue persisted. There are no other devices that could be possibly causing this so it might be a socket issue. Thought I'd run it by here first. Here are my results:
Modem stats:
Down Up
Rate: 288 kbs 445 kbs
Max Rate: 14925 kbs 1140 kbs
Noise Margin: 30.2 dB 27.6 dB
Attenuation: 20.2 dB 8.6 dB
Output Power: 9.3 dBm 11.5 dBm
Protocol: G.DMT2+ Annex A
Channel: Interleaved
DSLAM Vendor Information Country: {46336} Vendor: {IFTN} Specific: {48753 }
ATM PVC: 0/38
Rate Cap: 14925 kbs
Attenuation @ 300kHz: 20.2 dB
Uncanceled Echo: -2.4 dB Suspicious - check phone filters and alarm
VCXO Frequency Offset: -57.7 ppm Ok
Final Receive Gain: 23.8 dB Ok
Excessive Impulse Noise: 0 Ok
BT speed test:
1. Best Effort Test:  -provides background information.
Download  Speed
0.21 Mbps
0 Mbps 0.25 Mbps
Max Achievable Speed
Download speed achieved during the test was - 0.21 Mbps
For your connection, the acceptable range of speeds  is 0.1 Mbps-0.25 Mbps.
IP Profile for your line is - 0.25 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.09 Mbps
0 Mbps 0.45 Mbps
Upload speed  achieved during the test was - 0.09Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Current line speed =1Mb
So what's going on here? Any help is greatly appreciated. Thanks.
14 REPLIES 14
adamwalker
Fixes: 221
Re: Extremely slow speeds - possible filter/socket issue
If there was a fault with the filter it's likely that you'd notice that affecting your use of the phone too.
Was there anything connected to the line at all when you obtained those stats?
 Adam Walker
zenislev
Thanks for your reply Adam. All that's connected is a broadband router and phone via a new filter/splitter. Phone works fine.
jelv
Fixes: 10
Do you have more than one telephone socket in the house?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
zenislev
Yes, I should've mentioned: tried multiple sockets. Issue persists.
jelv
Fixes: 10
Do you have filters in all the sockets that are in use for anything (telephones, Sky box, alarms, emergency call buttons)?
zenislev
Only one socket is in use, and it has a filter on it. No alarm, skybox, etc.
adamwalker
Fixes: 221
Does your line have a <a href="http://www.plus.net/support/broadband/master-socket-guide.shtml#whatsTest">test socket?</a>?
If you have, get connected there and I'd like to run another test so I can compare the results to one I ran earlier for you.
Any noticeable difference should indicate if there's an issue with the socket.
Adam
 Adam Walker
zenislev
I'm not sure if there's a test socket - I vaguely remember a technician telling me that there wasn't one. I'd be able to open each socket up to look later, but I'm at work atm. Thanks.
jelv
Fixes: 10
You don't need to open up each socket, only any with a removable lower half (you will be able to see the split across the middle). There should be just one which will be the first socket from where the phone line enters the house.
zenislev
Thanks. I'll have a look when I get the chance. It's an apartment in a block of flats so I'm really not sure if there is a test socket.
zenislev
I'm afraid there's no test socket  Sad
Is it possible that a single faulty socket is causing problems, even if the router is connected to a different socket?
zenislev
Bump
jelv
Fixes: 10
It's just as likely to be the wiring as the actual sockets. Do you know which is the first socket where the line comes in to the house? If so the best you can do is to use that one and then carry on with the reporting a fault. If an engineer attends the first thing he should do is give you a proper master socket.
zenislev
I'm really not sure, but I'll take your advice and call in a fault. Thanks for your help!
