Extremely slow internet
mankoleb
My internet connection has slowed to a crawl. I'm looking at download speeds of 1 mbps.
2 REPLIES 2
Legend
Fixes: 254
Re: Extremely slow internet
Have you had a look at the ADSL - Speed faults sticky at the top of this forum?
Posting the details/results requested there would help others to help you.
Chris
Legend
Fixes: 169
Sorry you're having problems with your connection. Testing your line isn't showing any issues either, your current connection has been ongoing for 123 days, so there's no instablity causing issues either.
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
