Extremely reduced service in the evenings last few days
cerzi
Hello,
For the last few days we've had extremely slow download speeds in the evening, starting around 5ish - from our usual speed of around 40Mb/s down to 3-4Mb/s. I used the HELP SMS system but the advisor could not detect any issues. Would it be possible to further investigate this?
The router has been restarted etc, and the issue is external (nothing on the internal network hogging traffic).
Many thanks for any help!
31 REPLIES 31
Fixes: 334
Re: Extremely reduced service in the evenings last few days
@cerzi These things can be a pain to trace, but sight of your routers Help Desk or Technical Log would be a start.
For the Hub One -
For the Hub Two -
Please obscure your username.
cerzi
I don't use the Hub One/Two (have an ASUS TUF), this the general log though:
Sep 24 12:14:09 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 4E:C7:0C:65:AB:C9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 12:14:09 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 4E:C7:0C:65:AB:C9, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Sep 24 12:14:12 wlceventd: wlceventd_proc_event(685): eth6: Auth 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:0
Sep 24 12:14:12 wlceventd: wlceventd_proc_event(722): eth6: Assoc 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:-60
Sep 24 17:11:38 wlceventd: wlceventd_proc_event(831): eth6: Radar detected
Sep 24 17:11:38 kernel: In wl_dfs_cac_notify_status chanspec 0xe07a DFS state 3
Sep 24 17:11:39 cfg_server: cm_updateChanspec call wl_chanspec_changed_action
Sep 24 17:11:39 cfg_server: event: wl_chanspec_changed_action_a101 of eid(0) of cfgs(2184)
Sep 24 17:11:39 kernel: In wl_dfs_cac_notify_status chanspec 0xe32a DFS state 0
Sep 24 17:12:10 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 48:B0:2D:04:01:C1, status: 0, reason: Disassociated due to inactivity (4), rssi:-52
Sep 24 17:12:11 kernel: wl1: random key value: 0AF9FA18D36CF272531901EF7C28DEDE8779E1709A6103A22E89EB7B5841CF29
Sep 24 17:12:32 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind C6:18:1F:F5:5E:EB, status: 0, reason: Disassociated due to inactivity (4), rssi:-73
Sep 24 17:12:33 kernel: wl1: random key value: F60C9B82FD0B4DE24AAC01AB983E96BAD34BC1BFFE780D46DD949A949CA476E7
Sep 24 17:12:45 wlceventd: wlceventd_proc_event(685): eth5: Auth C6:18:1F:F5:5E:EB, status: Successful (0), rssi:0
Sep 24 17:12:45 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind C6:18:1F:F5:5E:EB, status: 0, reason: Unspecified reason (1), rssi:0
Sep 24 17:12:45 wlceventd: wlceventd_proc_event(722): eth5: Assoc C6:18:1F:F5:5E:EB, status: Successful (0), rssi:-51
Sep 24 17:13:03 bsd: bsd: Sending act Frame to c6:18:1f:f5:5e:eb with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 17:13:04 bsd: bsd: STA:c6:18:1f:f5:5e:eb no response
Sep 24 17:13:04 bsd: bsd: Sending act Frame to c6:18:1f:f5:5e:eb with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 17:13:05 bsd: bsd: STA:c6:18:1f:f5:5e:eb no response
Sep 24 17:13:05 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind C6:18:1F:F5:5E:EB, status: 0, reason: Previous authentication no longer valid (2), rssi:-50
Sep 24 17:13:06 wlceventd: wlceventd_proc_event(685): eth6: Auth C6:18:1F:F5:5E:EB, status: Successful (0), rssi:0
Sep 24 17:13:06 kernel: wl0: random key value: 993D53513DF9D30F2C7A02605029A6178C7E5187E03501557F65B08B6E727B9E
Sep 24 17:13:06 wlceventd: wlceventd_proc_event(662): eth5: Disassoc C6:18:1F:F5:5E:EB, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 17:13:06 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc C6:18:1F:F5:5E:EB, status: Successful (0), rssi:-67
Sep 24 17:31:42 wlceventd: wlceventd_proc_event(685): eth6: Auth 48:B0:2D:04:01:C1, status: Successful (0), rssi:0
Sep 24 17:31:42 wlceventd: wlceventd_proc_event(722): eth6: Assoc 48:B0:2D:04:01:C1, status: Successful (0), rssi:-67
Sep 24 17:38:38 wlceventd: wlceventd_proc_event(685): eth6: Auth F2:90:95:C7:59:1B, status: Successful (0), rssi:0
Sep 24 17:38:38 wlceventd: wlceventd_proc_event(722): eth6: Assoc F2:90:95:C7:59:1B, status: Successful (0), rssi:-91
Sep 24 17:38:56 wlceventd: wlceventd_proc_event(685): eth5: Auth F2:90:95:C7:59:1B, status: Successful (0), rssi:0
Sep 24 17:38:56 kernel: wl1: random key value: 323CD815CF7ACE0B00510113948799DE75E55B42B9C0025E69C4F759C07F8D4C
Sep 24 17:38:56 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc F2:90:95:C7:59:1B, status: Successful (0), rssi:-79
Sep 24 17:38:56 wlceventd: wlceventd_proc_event(662): eth6: Disassoc F2:90:95:C7:59:1B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 17:39:18 bsd: bsd: Sending act Frame to f2:90:95:c7:59:1b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 17:39:19 bsd: bsd: STA:f2:90:95:c7:59:1b no response
Sep 24 17:39:19 bsd: bsd: Sending act Frame to f2:90:95:c7:59:1b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 17:39:20 wlceventd: wlceventd_proc_event(685): eth6: Auth F2:90:95:C7:59:1B, status: Successful (0), rssi:0
Sep 24 17:39:20 kernel: wl0: random key value: CAAB550FA7FC22C163710276A182AE85A4DD2EB3AE0702BD966EF7C7F2ECCF69
Sep 24 17:39:20 wlceventd: wlceventd_proc_event(662): eth5: Disassoc F2:90:95:C7:59:1B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 17:39:20 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc F2:90:95:C7:59:1B, status: Successful (0), rssi:-63
Sep 24 17:39:20 bsd: bsd: STA:f2:90:95:c7:59:1b no response
Sep 24 17:40:05 wlceventd: wlceventd_proc_event(685): eth5: Auth 48:E1:E9:D9:98:93, status: Successful (0), rssi:0
Sep 24 17:40:05 wlceventd: wlceventd_proc_event(722): eth5: Assoc 48:E1:E9:D9:98:93, status: Successful (0), rssi:-52
Sep 24 17:43:33 cfg_server: cm_updateChanspec call wl_chanspec_changed_action
Sep 24 17:43:33 cfg_server: event: wl_chanspec_changed_action_a101 of eid(1) of cfgs(2184)
Sep 24 17:54:07 wlceventd: wlceventd_proc_event(685): eth6: Auth 04:D6:AA:9C:04:0B, status: Successful (0), rssi:-68
Sep 24 17:54:07 wlceventd: wlceventd_proc_event(722): eth6: Assoc 04:D6:AA:9C:04:0B, status: Successful (0), rssi:-68
Sep 24 17:55:43 wlceventd: wlceventd_proc_event(685): eth5: Auth 04:D6:AA:9C:04:0B, status: Successful (0), rssi:0
Sep 24 17:55:43 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 04:D6:AA:9C:04:0B, status: Successful (0), rssi:-70
Sep 24 17:55:43 kernel: wl1: random key value: A989A125D74BBDDC3F22029670DABA0DDC633F03A5050A256D06DB1474C7390C
Sep 24 17:55:43 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 04:D6:AA:9C:04:0B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 17:55:55 kernel: sched: RT throttling activated
Sep 24 17:58:43 bsd: bsd: Sending act Frame to 04:d6:aa:9c:04:0b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 17:58:43 bsd: bsd: BSS Transit Response: ifname=eth5, event=156, token=16, status=6, mac=34:0d:08:bf:b8:0d
Sep 24 17:58:43 bsd: bsd: BSS Transit Response: STA reject
Sep 24 17:58:43 bsd: bsd: Skip STA:04:d6:aa:9c:04:0b reject BSSID
Sep 24 18:04:09 bsd: bsd: Sending act Frame to 04:d6:aa:9c:04:0b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 18:04:09 bsd: bsd: BSS Transit Response: ifname=eth5, event=156, token=17, status=0, mac=08:bf:b8:0d:ef:74
Sep 24 18:04:09 bsd: bsd: BSS Transit Response: STA accept
Sep 24 18:04:09 wlceventd: wlceventd_proc_event(685): eth6: Auth 04:D6:AA:9C:04:0B, status: Successful (0), rssi:0
Sep 24 18:04:09 kernel: wl0: random key value: FF93AE5406E0678F74ED00C808DD19CA86C1673DC6920F78C6B2F879AD16C146
Sep 24 18:04:09 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 04:D6:AA:9C:04:0B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 18:04:09 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc 04:D6:AA:9C:04:0B, status: Successful (0), rssi:-57
Sep 24 18:04:56 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 86 and rssi is -67
Sep 24 18:05:01 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 86 and rssi is -67
Sep 24 18:05:12 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 86 and rssi is -67
Sep 24 18:05:21 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 86 and rssi is -67
Sep 24 18:05:31 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 86 and rssi is -67
Sep 24 18:05:41 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 86 and rssi is -67
Sep 24 18:05:51 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 88 and rssi is -66
Sep 24 18:05:56 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 82 and rssi is -69
Sep 24 18:06:02 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 18:06:11 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:11:17 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:12:16 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:16:21 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:16:26 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:17:11 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:33:01 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:33:51 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:43:16 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:43:51 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 18:44:31 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 19:00:41 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 19:00:51 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 19:01:01 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:01:06 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:01:11 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:01:27 wlceventd: wlceventd_proc_event(685): eth5: Auth 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:0
Sep 24 19:01:27 kernel: wl1: random key value: 5CAA1A8BAF1329A543FB0279EF83D92EB7C100595DE70372472D7833CCCF82F9
Sep 24 19:01:27 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:-70
Sep 24 19:01:27 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 4E:C7:0C:65:AB:C9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 19:01:31 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 19:01:37 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 19:01:50 wlceventd: wlceventd_proc_event(685): eth6: Auth 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:-75
Sep 24 19:01:50 kernel: wl0: random key value: 42D73BA146CAAFB87B76001AD0E9B45506F662C5DCFD02BF29B583BD0F6BFF06
Sep 24 19:01:50 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:-75
Sep 24 19:01:50 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 4E:C7:0C:65:AB:C9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 19:01:51 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 90 and rssi is -65
Sep 24 19:01:56 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:02:31 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:03:47 wlceventd: wlceventd_proc_event(685): eth5: Auth 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:0
Sep 24 19:03:47 kernel: wl1: random key value: C48CF2EDB85B57A77FD90279BD212600D667AF924FCB0AB66396A1E2BBF833F8
Sep 24 19:03:47 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:-67
Sep 24 19:03:47 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 4E:C7:0C:65:AB:C9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 19:06:42 bsd: bsd: Sending act Frame to 4e:c7:0c:65:ab:c9 with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 19:06:42 bsd: bsd: BSS Transit Response: ifname=eth5, event=156, token=18, status=0, mac=08:bf:b8:0d:ef:74
Sep 24 19:06:42 bsd: bsd: BSS Transit Response: STA accept
Sep 24 19:06:42 wlceventd: wlceventd_proc_event(685): eth6: Auth 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:0
Sep 24 19:06:42 kernel: wl0: random key value: DA980F425AEDD4306A0101DB5F18BE14283E8883AEA00F0D40065FEFC47E9E98
Sep 24 19:06:42 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc 4E:C7:0C:65:AB:C9, status: Successful (0), rssi:-43
Sep 24 19:06:42 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 4E:C7:0C:65:AB:C9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 19:07:37 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:08:31 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:09:31 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:09:41 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:09:51 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:10:16 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 92 and rssi is -64
Sep 24 19:10:26 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 94 and rssi is -63
Sep 24 19:10:38 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 48:E1:E9:D9:98:93, status: 0, reason: Disassociated due to inactivity (4), rssi:-55
Sep 24 19:10:39 kernel: wl0: random key value: 0145C8FA84C5E3B6484900200DED62824B9AE5B60BE40B25635EAD1C60C05A7A
Sep 24 19:14:31 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 72 and rssi is -74
Sep 24 19:14:46 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 68 and rssi is -76
Sep 24 19:14:53 wlceventd: wlceventd_proc_event(685): eth5: Auth 04:D6:AA:9C:04:0B, status: Successful (0), rssi:0
Sep 24 19:14:53 kernel: wl1: random key value: 47ECB67F82E8B82A4E500392888F0429DD997131C9190222FD398AF937199AAA
Sep 24 19:14:53 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 04:D6:AA:9C:04:0B, status: Successful (0), rssi:-67
Sep 24 19:14:53 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 04:D6:AA:9C:04:0B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 19:17:58 bsd: bsd: Sending act Frame to 04:d6:aa:9c:04:0b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 19:17:59 bsd: bsd: BSS Transit Response: ifname=eth5, event=156, token=19, status=6, mac=34:0d:08:bf:b8:0d
Sep 24 19:17:59 bsd: bsd: BSS Transit Response: STA reject
Sep 24 19:17:59 bsd: bsd: Skip STA:04:d6:aa:9c:04:0b reject BSSID
Sep 24 19:21:04 bsd: bsd: Sending act Frame to 04:d6:aa:9c:04:0b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 19:21:05 bsd: bsd: BSS Transit Response: ifname=eth5, event=156, token=1a, status=6, mac=34:0d:08:bf:b8:0d
Sep 24 19:21:05 bsd: bsd: BSS Transit Response: STA reject
Sep 24 19:21:05 bsd: bsd: Skip STA:04:d6:aa:9c:04:0b reject BSSID
Sep 24 19:21:41 wlceventd: wlceventd_proc_event(685): eth5: Auth 48:E1:E9:D9:98:93, status: Successful (0), rssi:0
Sep 24 19:21:41 wlceventd: wlceventd_proc_event(722): eth5: Assoc 48:E1:E9:D9:98:93, status: Successful (0), rssi:-51
Sep 24 19:24:10 bsd: bsd: Sending act Frame to 04:d6:aa:9c:04:0b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 19:24:11 bsd: bsd: BSS Transit Response: ifname=eth5, event=156, token=1b, status=6, mac=34:0d:08:bf:b8:0d
Sep 24 19:24:11 bsd: bsd: BSS Transit Response: STA reject
Sep 24 19:24:11 bsd: bsd: Skip STA:04:d6:aa:9c:04:0b reject BSSID
Sep 24 19:27:17 bsd: bsd: Sending act Frame to 04:d6:aa:9c:04:0b with transition target eth6 ssid 08:bf:b8:0d:ef:74
Sep 24 19:27:17 bsd: bsd: BSS Transit Response: ifname=eth5, event=156, token=1c, status=0, mac=08:bf:b8:0d:ef:74
Sep 24 19:27:17 bsd: bsd: BSS Transit Response: STA accept
Sep 24 19:27:17 wlceventd: wlceventd_proc_event(685): eth6: Auth 04:D6:AA:9C:04:0B, status: Successful (0), rssi:0
Sep 24 19:27:17 kernel: wl0: random key value: 2C8E8576A9CE2D59713B00847E68D7839869F6F6277A0DD4ADC6894C70273CB1
Sep 24 19:27:17 wlceventd: wlceventd_proc_event(695): eth6: ReAssoc 04:D6:AA:9C:04:0B, status: Successful (0), rssi:-63
Sep 24 19:27:17 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 04:D6:AA:9C:04:0B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Sep 24 19:29:11 roamast: sta[04:D6:AA:9C:04:0B] on ap[08:BF:B8:0D:EF:74], rcpi is 94 and rssi is -63
Fixes: 334
That is not what we are asking for/ I am not familiar with ASUS kit, but the below picture gives an idea of the data you were asked for:
cerzi
Sorry, I'm struggling to understand what specific info you're after - the screenshot shows serial number, firmware version, etc - presumably that info will be of little use given I am not using a hub router? If the Event Log is needed, is that not the log I posted above?
Fixes: 334
OK. Sorry, that is a screenshot of the PN Hub2 Technical log (cut short) but what we need is  essentially your DSL  uptime, connection speed, and SNR values (as a start).
Fixes: 334
@cerzi Having checked what an ASUS TUF is, it appears to be a laptop - are you saying that incorporates a router? I doubt it, TBH.
Mustrum
Fixes: 81
@cerzi  do you have a DSL version of the router, or are you using a separate modem? What is the Asus Router model number?
If it is a DSL router there should be a DSL Log Tab under the System Log folder which if you post will help.
Otherwise which modem are you using?
cerzi
Ok, I'm an idiot as I'm actually still using the hub two in bridge mode as a modem, so was able to directly connect to get the info you need:
Hopefully this might shed some light on the issue!
cerzi
It's an ASUS TUF-AX3000 - definitely not a laptop!😅 - only recently got it because I needed QoS, but anyway. Seems like the issue is with the line?
Mustrum
Fixes: 81
@cerzi  the evidence you have shown does not suggest a line issue, more likely to be congestion, either on your LAN or maybe elsewhere.
Fixes: 334
@cerzi Having seen that data, I agree with @Mustrum - you do bot have any connection issues. Do you have anything like OneDrive or similar?
As a  point of interest, as ASUS unhelpfully use the 'TUF'  label for laptops and routers, had you given the full model number for your router,my confusion would not have arisen.
cerzi
I am 100% certain it isn't LAN congestion, as I have been monitoring network traffic obsessively since the problem started over the weekend.
Here is the most recent tab of my speed tests (performed on the router), which show the sudden drop-off around 5pm reaching rock bottom around 9-10pm and then back to normal in the morning.Screenshot 2024-09-25 100905.png
And below is network traffic over the last 24 hours, as you can see in the evening when the router was reporting less than 2Mbps speeds the network traffic was relatively low, certainly not using all of the typical bandwidth available.
Any ideas what else can be tried? Should I escalate this with Plusnet or is there anything else to check? Have never experienced this kind of problem living at this address for nearly 15 years - and Plusnet for more than half of that!
cerzi
Also just for completeness here is the modem info, seems to show pretty much the same as yesterday despite the speed being restored, confirming what you have both said:
Product name,Plusnet Hub Two
Serial number,+108417+2315006350
Firmware version,v0.10.00.04201-PN (Thu Apr 20 16:54:19 2023)
Board version,R01
GUI version,1.9 16_08_2022
DSL uptime,2 days 14 Hours 22 Mins 31 Secs
Data rate,10.0 Mbps / 40.0 Mbps
Maximum Data rate,12.0 Mbps / 46.1 Mbps
Noise margin,6.4/7.4
Line attenuation,6.5/18.9
Signal attenuation,6.6/21.3
VLAN id,101
Upstream error control,Off
Downstream error control,Off
Data sent / received,-
Wireless Security,WPA2 (Recommanded)
Wireless mode,Mode 1
Firewall,On
MAC address,54:B7:BD:35:29:76
Software variant,-
Boot loader, 0.1.7-PN (Thu Nov 30 09:45:22 2017)
pvmb
Fixes: 7
I take it from the details about 2.5/5 GHz Wi-Fi that is how you are linking to the router? Can you try connecting via an Ethernet cable, as the speed problem may simply be a result of congestion on the Wi-Fi channels.
How many other Wi-Fi APs can you see displayed on your laptop at the time the slow downs occur?
