Explorer issues
- Explorer issues
Explorer issues
26-02-2010 9:22 PM
Hi, this is my first time posting on this forum, I recently set up my wireless broadband and for some reason explorer would not connect to the internet (even though I was connected via wireless) I had safari installed on my laptop and this works fine, however my itunes wont connect to the internet now...
Can someone give me some help or advice as I'm not the greatest with IT related issues!!
Any advice or help would be greatly apriciated!!
Message 1 of 6
(994 Views)
5 REPLIES 5
Re: Explorer issues
26-02-2010 9:34 PM
You are going to have to give us a bit more information
What operating system
Which version of explorer
Which firewall
Is the problem on the laptop or another computer
Which router and have you tried wired
Did you have a dial up modem on the computer before broadband
Which firewall
Message 2 of 6
(523 Views)
Re: Explorer issues
26-02-2010 9:56 PM
I'm using vista, it is version 8 of explorer, it seems to be both wired and wireless, I have tried connecting my iphone to the network and that doesnt seem to want to connect to the network either, the firewall is the windows one and I use avast anti virus, Ive only just signed up to plusnet so I've got the thompson router, Ive never used dial up on this laptop, I used to have 3 mobile broadband which worked fine with explorer,
Thank you for looking at this for me!
Message 3 of 6
(523 Views)
Re: Explorer issues
26-02-2010 10:41 PM
If you put this in the browser do you get anything http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
Message 4 of 6
(523 Views)
Re: Explorer issues
26-02-2010 10:57 PM
I have just booted into Vista (I normally use Windows 7)
If you click on Computer and then Network does it see the Thompson Router
If you open IE8 then select Tools, Internet Options then Connections and then LAN settings does it look like this picture
Message 5 of 6
(523 Views)
Re: Explorer issues
27-02-2010 4:53 PM
Thank you so much! I went though copying the LAN settings and explorer is now working!
Thanks again for helping me out I really appreciate it!
Best Regards
Emma
Best Regards
Emma
Message 6 of 6
(523 Views)
