Existing BB Premier Option 1 and BBYW - swaping questions
- Existing BB Premier Option 1 and BBYW - swaping qu...
01-08-2007 1:07 PM
I am currently on BB Option 1 legacy £21.99
I just have a couple of questions:
Can you swap between BBYW as often as you like during the year?
For example - I may opt for BBYW £14.99 for a few months but if the peak usage is insufficient a I can upgrade, and vice a versa
Also is there any cost/charge associated with downgrading?
What is the overnight unlimited usage allowance time with BBYW?
Re: Existing BB Premier Option 1 and BBYW - swaping questions
01-08-2007 1:09 PM
(Let's see if I can get this in before Chris and Liam reply!).
There are no downgrade charges.
There is no set limit to overnight usage.
You can change your account type once a month.
01-08-2007 1:17 PM
Quote What is the overnight unlimited usage allowance time with BBYW?
Overnight usage times on BBYW are from Midnight - 8am
01-08-2007 1:18 PM
So if I choose to place an order to downgrade will it kick in next month (my bill date is at the very end of the month)?
01-08-2007 1:20 PM
We'll schedule your account to change on your next billing date.
06-08-2007 3:56 PM
Quote from: rafael Cheers James
Did you not get the hint midnight to 8am off peak
instead of midnight to 4pm
You lose 8 hours off peak time per day with BBYW
Cancel it if you can?
Michael
06-08-2007 3:59 PM
Different things suit different people. Everyone is different
15-08-2007 8:27 PM
Ie is one day before your billing enough time to switch?
15-08-2007 9:29 PM
Hopefully the change in Peak Time hours will not prove to be too much of a problem with just surfing the net during these hours. Any dowloading I'll have to do in the main betweem Midnight and 8am.
BTW if you decide to go ahead, make sure you are aware that you can have a new router for a £5.99 delivery charge by raising a ticket.
15-08-2007 9:46 PM
David
15-08-2007 9:55 PM
Also on Premier I the peak time allowance is 20GB, it's only at 13 GB when light restrictions apply.
However I have to say I not sure whether the same restrictions are in force on BBYW Option 3.
Can we use our full 20GB without restrictions kicking in?
15-08-2007 10:13 PM
Quote from: coastergrotto Can we use our full 20GB without restrictions kicking in?
Yes, you can.
15-08-2007 10:15 PM
