Excruciatingly low speeds.
coatseh
Hi, Recently I have been getting speeds on under 2mb download (average around 0.7mb) and even lower upload speeds.
I normally get around 12mb+ download.so I am totally perplexed as to why this is occuring. Here are a few router stats.
                             Upstream Downstream
Current Rate (Kbps) 1056 15704
Max Rate (Kbps) 1060 15916
SNR Margin (dB) 7.4 12.4
Line Attenuation (dB) 3.5 16.5
Errors (Pkts) 0 0
I know that isn't a lot to go on, but let me know any more information you need and I will provide it!
Thank you!
Plusnet Staff
Plusnet Staff
Fixes: 117
Re: Excruciatingly low speeds.
Hey there. Sorry to hear you're experiencing slow speeds. I've looked into your account and I'm not finding any issues. Are you connecting over wireless?
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
coatseh
Yes all devices are via wireless.
My laptop/computer seem fine now however my xbox one is still getting very low speeds (less than 1mb).
Plusnet Staff
Plusnet Staff
Fixes: 117
I'd probably suggest seeing if your speed is any better/more stable with a PC or laptop connected via an Ethernet cable to the router.
Here's a guide about wireless connectivity:
http://www.plus.net/help/broadband/getting-the-best-wifi-signal/
Let us know how you get on or if it's no better via Ethernet.
 Plusnet Staff
