Exclamation mark next to Wifi icon - Kindle Fire's
- Exclamation mark next to Wifi icon - Kindle Fire's
31-12-2015 11:21 AM
Good morning fellow PNers!!
I've got a Kindle Fire (which runs Amazon's branded version of Android) and today I've noticed there's an exclamation mark next to the Wifi icon at the top of the screen. We also have a Hudl2 having just checked it's showing the same 'problem'.
I've reset the PN router, change wifi channel several times and even dragged out the BT Hub and connected that up to run Plusnet through, but still the problem persists!
Any advice on how to sort or indication of what the issue is would be greatly apprecaited.
Cheers, Mike.
Re: Exclamation mark next to Wifi icon - Kindle Fire's
31-12-2015 12:16 PM
Works fine.
Have you entered your wifi password settings into your HUDL/KINDLE Fire at one point so
that the handshake takes place? After that should do it automatically when devices in range.
Click on the wifi exclamation mark icon; see what it says; could your devices be trying to connect to a neighbour's modem?
31-12-2015 12:30 PM
If you turn off Wifi and then back on again there's a message saying "No Internet Access Detected, won't reconnect automatically"
EDIT: If you click on the router name it shows as "Connected" but seems to have limited access. Internet works of a fashion, but can't seem to download apps etc as it just hangs.
31-12-2015 2:09 PM
01-01-2016 10:48 AM
01-01-2016 12:19 PM
Do you have any equipment other than the hudl or Kindle that does connect/is connected to the internet at this moment? If you do then the problem is internal and something to do with the wireless or hudl/kindle but if you have no other equipment that connects then it may be that your broadband connection is broken somewhere between you and Plusnet. Best of luck with curing whichever it is.
02-01-2016 10:42 AM
The "problem" has corrected itself without me making any further changes or amendments, so can only assume there was some temporary issue with the connection.
Thanks for the replies.
02-01-2016 11:26 AM
One frequently reoccurring problem with wifi devices is that they connect to the wifi infrastructure but do not successfully obtain an IP address for the LAN. You can determine if this applies by inspecting the network details in the device - if the IP address details are incomplete (for example no gateway address) then the device did not successfully obtain an address from the router after successfully connecting to the wifi network.
