Exchange upgraded to ADSL2+
moffat2000
Hello!
My exchange is now on ADSL2+. Is it correct that it'll take 5 weeks to upgrade my account or can the upgrade happen faster.
Please excuse my impatience, I'm just really looking forward to increases speed.  Wink
Fixes: 77
Re: Exchange upgraded to ADSL2+
Morning moffat2000,
We have a bulk order in place for you which is due to complete on the 20th.
 Adam Walker
moffat2000
Excellent. Many thanks.
itsme
Looking at your posts which have your line stats it's worrying that you are syncing at around 7500kbps with a 6dB SNRM. I would expect the margin to be much higher with an attenuation of 22dB. It may be worth looking at http://www.kitz.co.uk/adsl/socket.htm especially the ring wire section to see if you can improve your line before switch-over.
moffat2000
Thanks for the reply.
My current stats are as follows;
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,360
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 10.5 / 22.0
SN Margin (Up/Down) [dB]: 22.0 / 7.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 71,340
CRC Errors (Up/Down): 0 / 51
HEC Errors (Up/Down): 0 / 46
My profile sits at about 6 or 6.5 and i get download speeds of a little shy of 6Mb.
What should I expect my SNRM to be, roughly? Am I right in thinking that my line may be unstable on ADSL2 with my current SNRM?
Again, thanks for flagging this up.
houlton23
Quote from: moffat2000
What itsme is trying to say is that with your attenuation (a measure of line length - 22dB or ~ 1.6km) you should be syncing at the maximum speed for ADSL1 (8128kbps), however you are not and the impact may not be too great on ADSL1 but it may be worsened by the switch to ADSL2+, and you may receive a slower speed than you should be getting.
For that reason itsme suggested that you check if the ring wire (see the link in the previous reply) is limiting the speed.
Alex Smiley
moffat2000
I see.
Thanks to you both. I'll have a look at the wiring and see if I can improve it before the switchover.
Thanks again.
moffat2000
So I upgraded my internal wiring and fitted an ADSL filter plate to my master socket for good measure.
My attenuation dropped to 20db and my router is now syncing at 8128.
So again a big thanks to Itsme and Alex for the great advice.
Forum power at its best.  Cheesy
Fixes: 77
Glad to hear you got that sorted, I'll make sure your gratitude gets passed on.
 Adam Walker
