Exchange being upgraded to 21CN, quick question
ChuckHunky
My exchange is being upgraded to 21CN WBC in a couple of months. Does anyone know if I will automatically (or after a router reboot) start seeing the benefit once it is upgraded, or will I need to notify Plus.net so they can make changes?
Cheers
Fixes: 35
Re: Exchange being upgraded to 21CN, quick question
We'd need to process an order to modify the connection to 21CN for you after the exchange upgrade.
We do those automatically in bulk but feel free to post when you know the exchange has been upgraded and we won't mind manually placing an order for you. FYI it should only take 24 working hours to complete too.
Adam
 Adam Walker
ChuckHunky
Hi Adam
That's great, thanks for your speedy reply!
Cheers
Andrew
Fixes: 35
No worries! Smiley
 Adam Walker
