Exchange Congestion and move to 21CN
Fixes: 50
If I am on 20CN and my exchange is congested (VP issues), I then move to 21CN, does the congestion still apply?
Customer and Forum Moderator.
Fixes: 46
Re: Exchange Congestion
I imagine not since physical rejumpering from DSLAM to MSAN is involved. In fact there is mention in these forums of users on a congested VP being moved to a less congested one (20CN in both cases) to fix peak time speed issues.
David
Fixes: 50
Thanks spraxyt.
I am due to be moved onto 21CN this week and although my exchange shows green my D/L speeds are consistently around 6.5Mbs during the day but drop to around 2Mbs in the evening rush hour.
I was therefore hoping the move might alleviate this issue.
Fixes: 34
Yep,  spraxyt is right there, 20CN and 21CN capacity are managed separately by BTW.
 Adam Walker
Fixes: 50
Thanks guys.
My IP Profile is now 12.19Mbs having been ADSL2+ enabled at around 1:30 this afternoon Smiley
I guess I should leave it alone for 10 days before nudging for a PN profile update which is currently 7.15.
Download speed achieved during the test was - 6.61 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 12.19 Mbps
Upload speed achieved during the test was - 0.97Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
PS Very happy so far Smiley Ping is down from 16ms to 13ms Smiley
Welcome to the twenty-first century Strat.  Grin
Now, how long before you have fibre available?  Lips are sealed
Call me 'w23'
Fixes: 50
Fibre has been available for over a month now but I'm easing my network into higher data rates gradually Smiley
Fixes: 21
And your bill into a higher rate as well then  Grin
I feel you should be asking PN for your current line speed to be upped forthwith!
Fixes: 50
Thanks Anotherone, I will.
What a difference a day makes Smiley
Fixes: 46
Looks promising.  Smiley
Asking Plusnet to increase your Plusnet Profile to 12.1Mbps will ensure training takes place at the correct transfer rates.
Presumably you still have a 6dB downstream target noise margin. The DLM might try 3dB is error rates are low.
David
Fixes: 50
If one of the DC Team is around and feeling like working after last night's disappointment at the ISPA Awards.....could I have my PN profile nudged up to at least 12.1Mbs Smiley
Quote from: BT
Download speedachieved during the test was - 6.61 Mbps
Why is my upload speed exceeding maximum achievable Undecided
Upload speed achieved during the test was - 0.91Mbps
Not complaining, just curious.
jojopillo
Re: Exchange Congestion and move to 21CN
Hi Strat,
I've changed your profile to 12100 on our side, so you should see the change in the next 15 minutes.
Quote from: Strat
What disappointment? We won Best Consumer Fixed Broadband! Smiley
Jojo Smiley
Fixes: 50
But you deserved more Sad
Thanks Jo Smiley
