Exceeding your limit
- Exceeding your limit
08-07-2008 10:22 PM
Hi.
Just had email from Plusnet telling me I'm close to exceeding my monthly 30GB.
Checking my useage I've used 24.06 GB with approx 7 days before my monthly
30GB is restored on 16th of month.
Do Plusnet normally send warning mail so early ??with six GB to use in the next week.
Anyone ?
Anyone ?
Message 1 of 6
(1,253 Views)
5 REPLIES 5
Re: Exceeding your limit
08-07-2008 10:24 PM
I believe the mail goes out when you hit around 80% of your current usage. As you're a more heavy peak-time user, the idea is that the likelihood of you using the remaining 6GB is fairly high.
B.
B.
Message 2 of 6
(520 Views)
08-07-2008 10:26 PM
Barry has hit the nail on the head, the warning is sent when you hit 80% of your allowance to give you plenty of notice that you are getting close.
Message 3 of 6
(520 Views)
08-07-2008 10:30 PM
Not sure about early if you have used 24.06Gb over the past 3 weeks. If you continue at the same rate your would have exceeded your limit before then end of the week. The warning emails are sent when you have used 80% of your allowance. This is the Blog entry about it.
Message 4 of 6
(520 Views)
08-07-2008 10:31 PM
Ok, I took too long to type and locate the blog entry
Message 5 of 6
(520 Views)
08-07-2008 10:48 PM
Quote from: Barry I believe the mail goes out when you hit around 80% of your current usage. As you're a more heavy peak-time user, the idea is that the likelihood of you using the remaining 6GB is fairly high.
B.
Hi Barry and all others who replied.
Yes have been hitting it a bit hard this month but was aware of my current useage and I have used very little over last six days.
Was not aware of the 80% thing tho, so thanks for that info.
Thanks to all again.
Another Barry
Message 6 of 6
(520 Views)
