Exceeding allowance.
Fixes: 9
Quite likely I will exceed my monthly allowance but am quite willing to pay for an additional amount if I reach the agreed limit, just a couple of questions.
1. As I approach my monthly limit will my speeds be reduced
2. What number of extra GB's will be added to my account.
3. What will the cost be.
1 REPLY
pwatson
Re: Exceeding allowance.
The answer to this depends on what product you have...
See here for Plusnet Extra for instance - 5GB extra for £5 or your speed is capped to 256kbps
