Everytime I go away
- Re: Everytime I go away
Everytime I go away
06-11-2008 3:11 PM
The router is under a year old but suppose that could be the problem. Now to what I think it may well be but can't be sure, this is a rented house and the tennants before me whether first generation or later ; got into the socket and mucked things about. They use to have two lines at the house. I have only one, and had to stick the box back into the wall and only just managed to sort out their hodge podge DIY wiring. The router is now set up in the same room as the xocket is instead of traveling outside all round the house and in a bedroom and out again into the conservatory to the dining room. yea it was bad.
My problem is if I call BT I will have no doubts I will have to pick up the hefty charges as the landlord already have said you have a live live ..end of story. So I suppose I am stuck with it.
06-11-2008 3:13 PM
Is your connection wired or wireless?
If you're talking about a wired connection, make sure that your router is wired into your master socket via a filter, all of your used sockets are filtered and try using different filters.
It would also be a good idea to try using a different router if at all possible.
06-11-2008 3:17 PM
I had the router just sitting on a shelf of the desk, and noticed it was quite warm so raised it up on two small block to let air get all the way round it. that made no difference; will have to see who among friends has a router I can borrow for a while
thanks again for a speedy response.
06-11-2008 3:19 PM
See if you can borrow some equipment from a friend just to ensure that it's not your kit causing the problem, and causing a call out charge from BT if that were found to be the case.
06-11-2008 3:22 PM
Quote Just because they're less than a year old, doesn't mean that they work properly
Yep how true, but sometimes that is about the only benchmark we have I am 50 and my mrs reckon I still work well
06-11-2008 3:26 PM
It may also be worth checking that your router has no idle timeouts set, i.e. any box marked "always on" in its setup is ticked or, if there's an idle timeout, setting the time to 0 usually does the trick.
What make and model of router is it?
06-11-2008 3:28 PM
I've had a look at your connection logs and I can see numerous physical drops. There's an issue with any of:
- Your router
- Your filters
- Your internal wiring
- Your telephone line
- The BT exchange
We need to get the top 3 isolated first before we get BT involved.
06-11-2008 3:35 PM
06-11-2008 3:40 PM
router Dynamode R-ASDL-C4-2
I'll have a look through the settings and check....
Like that Ian.
Constant Craving or Can't stand Gravy KD Lang
06-11-2008 3:48 PM
If it's any help, here is a link to the router's quick start guide.
You can set the idle timeout on the configuration page (in stage 3). You need to make sure that the figure is 0 and that the "Automatic Reconnect" box is ticked.
It looks like those are the defaults though - so if you've checked and they are set as described then you'll need to try another router, filters, etc. as per Jamseh's post.
Also, this link to the full manual may be of use.
06-11-2008 3:49 PM
06-11-2008 3:55 PM
06-11-2008 3:57 PM
06-11-2008 4:11 PM
I haven't a clue what this means it is in the DSL Status window on the router pages
Super Frame Errors downstream 2 Upstream 0
06-11-2008 9:03 PM
Quote just the wires in terminals 2 and 5 remain (which are usually blue/white and white/blue)
NB! If your wiring has different colours, remember it's not the colour that matters, it's what is connected to terminal 3 and 4 that needs to be removed.
Disconnecting the orange bellwire can make a big improvement in connection stabilty
