Evening no broadband - throttled
- Evening no broadband - throttled
24-04-2011 10:53 AM
Hi
after months of lovely stable broadband....
I have no broadband for the last 4 or 5 evenings.
During the day I get 5Mbps (lovely) but between
approx 6pm and 1am I get 100bps!!!!
Basically no Internet of an evening to browse of stream.
My current line speed is 7.15Mb and router 8128kbps sync.
Nothing obvious.
By speedtest results Mbps:
date. Time. Down. Up
20th 18:09. 0.09. 0.33
21:13. 0.09. 0.35
21st. 02:18. 4.21. 0.31
06:27. 5.61. 0.33
14:50. 4.73. 0.28
23:08. 0.12. 0.32
22nd. 02:37. 5.04. 0.31
05:55. 5.20. 0.28
20:52. 0.09. 0.31
22:09. 0.09. 0.28
23rd. 06:22. 5.21. 0.26
13:16. 3.96. 0.32
18:43. 0.09. 0.32
21.55. 0.09. 0.27
does anybody have an idea why downloads would be stuck to near 100kbps
during the evenings for the last few days?
I am a low user a few GBs per month so somewhat bemused.
Nothing has changed at home in relation to wiring or electronics.
Thanks in advance
plantagenet
Nothing obvious.
21:13. 0.09. 0.35
06:27. 5.61. 0.33
14:50. 4.73. 0.28
23:08. 0.12. 0.32
05:55. 5.20. 0.28
20:52. 0.09. 0.31
22:09. 0.09. 0.28
13:16. 3.96. 0.32
18:43. 0.09. 0.32
21.55. 0.09. 0.27
Thanks in advance
plantagenet
Message 1 of 5
(1,074 Views)
4 REPLIES 4
Re: Evening no broadband - throttled
26-04-2011 1:50 PM
HI Plantagenet,
On the surface of it, it sounds like a contention issue. If you can conduct some speed tests at http://speedtester.bt.com when it's good and then when it's bad and then raise a fault we can get it looked into further. In the meantime I will email BT and get the VP checked to see if this is the cause.
Jojo
Jojo
Message 2 of 5
(604 Views)
26-04-2011 7:45 PM
Hi Jojo
Thanks for the reply.
I have not opened a fault as Murphy's law goes all has been fine since I posted my message.
All is back to normal, will continue to monitor but looks ok.
One of those things, perhaps it was contention especially being a long BH weekend.
Thanks again
Plantagenet
Thanks again
Plantagenet
Message 3 of 5
(604 Views)
27-04-2011 10:53 AM
HI Plantagenet,
It does look as though you are suffering some occasional peak time slow downs. The reply I received from the email is below...
[quote= BT email]The VP associated with your customers circuit has been identified as having utilisation issues.
BT Operate are investigating this VP and looking at ways of resolving the congestion issue.
A new report will be produced on 29th April and a further update will be available upon request at this time.
I'll check again for you next week.
Jojo
Jojo
Message 4 of 5
(604 Views)
04-05-2011 7:33 AM
Hi Plantagenet,
I've been liaising with BT and have just had this email back...
[quote=BT email]Hi Joanne
I have checked and this VP is currently running hot. One option would be to move your customer on to a VP that is not over utilised, however, they would be without service for 1-3 working days. Please advise if you would like to take this option.
Jojo
Jojo
Message 5 of 5
(604 Views)
