Evening dropouts
- Evening dropouts
Evening dropouts
16-05-2013 2:05 PM
pretty much every evening I get at least 4 dropouts. Doesn't seem to happen during the daytime
Internet slows to a halt, router CRC errors increase until sync is lost.
It then resyncs, normally to different IP and gateway, without any drop in speed.
often the drops are at approx 19:30, 21:00, 22:30 ie just in the middle of streaming film
I'll post info from router, router stats and speed tests when I get home but in the mean time :
snr = 0.1
download speed is usually 10.5 mbs
router is in main (only) bt socket, new filters, silent phone test is not noisy
snr = 0.1
Message 1 of 9
(1,337 Views)
8 REPLIES 8
Re: Evening dropouts
16-05-2013 2:29 PM
Looking at the logs of your router's connections and disconnections it looks like it may be dropping in the early morning too:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13687106304168.png"/>
I'm wondering if the times of the drops indicated on the graph are when the connection is in use?
Are you able to get your hands on another router to try as that's one likely thing that could be causing this.Other potential causes for these types of issues can be timed devices like central heating/boilers etc but I'd try and eliminate the router first if you can.
Adam
Adam
Message 2 of 9
(831 Views)
16-05-2013 2:53 PM
I get the same problem now and again as mentioned in a previous post a few days ago.
It's just happened again - I clocked it at 14.37 and the connection has just been restored 14.52
Message 3 of 9
(831 Views)
16-05-2013 2:59 PM
@smokeyone
If you look at your disconnections compared to @stevegow's there doesn't appear to be a pattern to the issues you're seeing:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13687125142631.png"/>
So it looks like the disconnections have ramped up unfortunately since I looked at this post for you: http://community.plus.net/forum/index.php/topic,114922.msg990117.html#msg990117
My next advice would be to head to our fault checker: http://faults.plus.net
Adam
Adam
Message 4 of 9
(831 Views)
16-05-2013 4:21 PM
I realise you are trying to be helpful but I have been through all this before - a couple of months back -
true there does not seem to be a pattern but it does seem to be re-curring -
Message 5 of 9
(831 Views)
16-05-2013 4:51 PM
OK, I'd still urge you to report it as the previous tickets have been closed. The fault checker is the quickest way to do so. If you'd rather not do that then give us a call on 0800 432 0200
Let us know if you have any issues beyond that.
Best regards,
Adam.
Best regards,
Adam.
Message 6 of 9
(831 Views)
16-05-2013 5:09 PM
Adam
I have the original plusnet supplied Thompson router
I'll try that for a few days
I don't believe that anything like heating is happening at those times. Everything would be off after about 22:30
TIA
TIA
Message 7 of 9
(831 Views)
16-05-2013 5:26 PM
Message 8 of 9
(831 Views)
18-05-2013 2:40 PM
Swapped back to Thompson TG585 v7 on Thursday evening
Seems not to be dropping
Link Information
Uptime: 1 day, 19:06:29
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 13,430
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 16.0 / 31.5
SN Margin (Up/Down) [dB]: 27.0 / 3.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): NA / 25,737,377
CRC Errors (Up/Down): NA / 349
HEC Errors (Up/Down): 0 / 328
I've ordered a new router via customer service anyway
Link Information
Message 9 of 9
(831 Views)
