Ethernet connection
stevejd58
Ethernet connection
I have an Ethernet connectivity problem although my WiFi is fine but slower than wired.
Pc is windows 11 24H2 build 26100.3915 accessing plusnet via a TP Link Deco X20, ethernet via a TP Link powerline set up, security is Bitdefender Total Security.
My son is also on a powerline adapter and has no ethernet connection issues whatsoever, so I'm guessing its to do with my pc settings.
The get help option in the network settings states that no DHCP was found and the connection comes up as an unidentified connection.
I have tried the obvious and changed the cable although the ethernet lights were showing activity on the old one as well.
I have completed the ipconfig clear and reset options in CMD with no effect.
The Deco control panel is app based and not that useful.
I'm wondering if manually setting my ethernet connection is the way to go and if so what are the settings in  windows 11?
22 REPLIES 22
Fixes: 459
Re: Ethernet connection
Moderator's note:
Thread moved from Broadband to Tech Help.
Fixes: 459
How are your Powerline devices configured? Can you confirm that there is a single powerline device connected to your router with both satellites units slaved from it? If so, the two satellites should be interchangeable.
stevejd58
Powerline setup is as follows
TP-link Deco X20 set up as a DSL (FTTC) modem router, connected to a powerline plug with three other plugs paired with it
Sky box and son's pc connected to additional plugs with no connection issues.
This pc (currently on wifi) connected to a forth powerline plug shows network activity at pc ethernet port but no internet connection.
I have exchanged the plug from mine to a known working one and this shows there is no fault in any of the plugs.
It has to be a windows 11 setting issue that's not allowing ethernet connection.
Network and internet settings show no internet connection
bobpullen
Fixes: 327
Has is ever worked?
What is the output of ipconfig /all for the Ethernet adapter of the affected PC (whilst plugged into the Powerline adapter)?
If you check the TCP/IP v4 properties for the Ethernet Adapter is everything configured to obtain details automatically?
stevejd58
Yes it has worked since install, this seems to be a recent issue.
Yes, settings for TCP/IP v4 are set to automatic
stevejd58
I also did a windows reset/repair which also made no difference
Still coming up with no DHCP server found
bobpullen
Fixes: 327
You can try manually configuring the TCP/IP properties but given the symptoms you describe, I'd be surprised if it helped (for IP, make sure you use an address that no other device on your network has): -
IP: 192.168.1.50
Gateway: 192.168.1.254
Subnet mask: 255.255.255.0
DNS: 212.159.6.9
DNS: 212.159.6.10
As mentioned previously, running 'ipconfig /all' from a Windows command line (before attempting manual config) will show the configuration of the network adapter which may offer some clues. I suspect it's probably going to show that the adapter is assigned an APIPA address though (i.e. something in the range 169.254.0.0/16).
It does sound like something specific to the Powerline adapter/your PC. Is it definitely on the same electrical circuit and have you tried swapping your Ethernet cables out? If you swap your Powerline unit with a 'working' one, are you saying that the working also fails to work at the Desktop PC's location?
Assume it's not practical to try cabling the PC to the location of one of the 'working' Powerlines?
stevejd58
Hi Bob
I tried your settings suggestion without any success.
Ipconfig /all comes up with the following
C:\Windows\System32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : StevesPC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : FC-34-97-97-50-2D
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::a72d:50de:580a:2aef%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.50(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 133969047
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2D-EB-E1-6C-FC-34-97-97-50-2D
DNS Servers . . . . . . . . . . . : 212.159.6.9
212.159.6.10
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Local Area Connection* 8:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 68-54-5A-AD-0E-27
DHCP Enabled. . . . . . . . . . . : Yes
Wireless LAN adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 6A-54-5A-AD-0E-26
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX200 160MHz
Physical Address. . . . . . . . . : 68-54-5A-AD-0E-26
Link-local IPv6 Address . . . . . : fe80::f30f:5b2c:db6d:7467%5(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.68.57(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.252.0
Lease Obtained. . . . . . . . . . : 08 May 2025 19:48:45
Lease Expires . . . . . . . . . . : 08 May 2025 21:48:45
Default Gateway . . . . . . . . . : 192.168.68.1
DHCP Server . . . . . . . . . . . : 192.168.68.1
DHCPv6 IAID . . . . . . . . . . . : 141055066
DNS Servers . . . . . . . . . . . : 1.1.1.1
1.0.0.1
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 68-54-5A-AD-0E-2A
The powerline adapter worked previously but I didn't notice the swap to wifi when it dropped, only noticing when I realised a download was very slow.I've swapped powerline plugs and the one from my PC works fine in its new location so that rules the plugs out of the equation, the plug I now use had connectivity but doesn't no it is with my PC, all plugs are on the same ring main. My PC ethernet port is showing activity so I assume it is receiving some data. Sadly the next nearest powerline or the modem/router is is not reachable with the cables I have to hand
bobpullen
Fixes: 327
Looking at the Ethernet config, I’m assuming you ran that command after making the manual changes rather than before? It’s the before that would have been more telling.
Although I realise from looking at the Wi-Fi config that I’ve probably given you the wrong details anyway. Is the IP of the router you’re using 192.168.68.1? If so, then that should be your gateway address for the Ethernet connection, and the IP should be something in the same subnet (but not used elsewhere) e.g. 192.168.68.50.
 In my haste, I gave you the details you would typically use with a Plusnet hub 🙄
Fixes: 124
@stevejd58
I note both the wired and wireless interfaces are enabled, any reason for this? There are on different networks which is not helpful for routing.
If you are intending to use the ethernet connection then turn OFF wireless.
What exactly is your setup the Deco X20 I find is a router or wireless access point device, a modem would be required for DSL.
Which powerline adapters are you using, are they all paired with each other to form one network?
bobpullen
Fixes: 327
Further to @Dan_the_Van's questions, perhaps a more succinct one: is there a Plusnet router in use anywhere on your network? If the answer to this question is 'yes', and you haven't made any changes to the Plusnet hub's config, then it looks like you have two DHCP servers on your LAN which is ill-advised.
stevejd58
Hi Dan
The deco setup is in post 4 of this thread, set up as a DSL Modem Router.
wireless is on as ethernet will not allow access to the internet
stevejd58
Hi Bob
 no there isn't a plusnet hub on my set up.
re the x2 dhcp servers, how do I remove/rest this to a solo server?
updated IP address
Link-local IPv6 Address . . . . . : fe80::a72d:50de:580a:2aef%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.48(Preferred)
212.159.6.10
Lease Obtained. . . . . . . . . . : 09 May 2025 08:55:02
Lease Expires . . . . . . . . . . : 09 May 2025 11:06:23
1.0.0.1
bobpullen
Fixes: 327
If the IP address of the Deco is 192.168.68.1 then this is not going to work. The gateway address needs to be that of the Deco: -
I would suggest changing the TCPv4 properties back to obtain automatically and then reboot the PC. When it comes back it would be interesting to see output of the command again.
You could then try manually configuring the properties again if you like but ensuring the gateway IP is 192.168.68.1 (although as mentioned, I'm somewhat doubtful it's going to help).
