Estimated speed higher than current line speed?
- Estimated speed higher than current line speed?
09-04-2013 9:10 PM
Hi, got my unlimited fiber installed today but I have a query with these stats
Estimated line speed:
57Mb (Accurate to within +/- 1Mbit) - Checked on 2013-03-27 16:05:19
Current line speed:
37 Mb
Is this right? speedtest.net says 36mb down and 14 up.
thanks
Current line speed:
37 Mb
thanks
Message 1 of 5
(901 Views)
4 REPLIES 4
Re: Estimated speed higher than current line speed?
09-04-2013 10:41 PM
Your line will just need to stabilise. As it was just installed, the Dslam needs to find the highest speed your line can handle. So presumably it will be higher tomorrow.
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 2 of 5
(451 Views)
09-04-2013 10:46 PM
Are you on Fibre essentials as that is the limit on that.
If you are on unlimited it could be a mistake
Running the BT speed test to check the IP profile (further diagnostics option) and it that is much higher then Plusnet may have got it wrong
Message 3 of 5
(451 Views)
10-04-2013 12:08 PM
Iam on fibre unlimited my usage says i have 0kb allowance so assume this is correct.
Bt speed test shows iam on 72mb profile with current speed at 37mb.
Am I right in thinking plusnet need do manually change my profile 24hr after install? If so they havnt yet.
dick:quote
dick:quote
Message 4 of 5
(451 Views)
10-04-2013 2:01 PM
Sorry about that, just tweaked things on our side for you - hope that's made a difference?
Message 5 of 5
(451 Views)
