turn on suggestions
Estimated line speed..
- Estimated line speed..
13-03-2014 11:44 AM
Last couple of checks have dropped this figure to 1Mb, it's always been 4Mb/ish
Any idea what's going on?
Also the profile seems to be stuck since this first happened, could someone check/confirm and maybe fix it for me?
Cheers.
Quote Estimated line speed:
1.0Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2014-03-12 07:12:48
Current line speed:
4.9 Mb
Cheers.
Re: Estimated line speed..
13-03-2014 1:46 PM
Hi Pedro,
I've had a look and given your connection profile on your account a slight nudge up to 5.3Mbps.
I wouldn't worry too much about the estimates that you're quoted. If the actual speed is correct then that's absolutely fine. If you notice a drop in speeds then do let us know and we can take a look at that for you.
13-03-2014 2:07 PM
Hi Linn,
Many thanks for the clarification and the nudge, appreciate it.
Cheers.
Cheers.
13-03-2014 2:21 PM
No problem Pedro
