Estimated line speed - opt out
- Estimated line speed - opt out
Re: Estimated line speed - opt out
04-04-2011 10:00 PM
05-04-2011 12:50 AM
Of course now all the questions are "where has my estimated speed gone?".
05-04-2011 7:58 AM
Mine's still present so it's not a service-wide problem. My guess would be that we fixed something a while back that's inadvertently broke this for some of you. Interestingly, those affected don't have this field present on their account at all when checking our internal CRM systems (which would explain why it's no longer visible on the portal).
Anyway, a problem has been raised to have it looked into (ref: 66515) but it's not particularly high on the list of priorities at the moment.
06-04-2011 7:57 AM
06-04-2011 7:57 PM
Quote Estimated line speed:
1.0Mb (This may vary between 1Mb and 3.5Mb) - Checked on 2011-02-21 03:29:44
Current line speed:
6 Mb
I'm curious as to where the "Estimated line speed" actually comes from. At the time it was last "checked", my actual IP profile would have been around 4 or 5 Mb; certainly nowhere near the 1.0Mb quoted above. Where does this figure of 1.0Mb come from, and how was it "checked"?
06-04-2011 9:12 PM
I am a long-term customer - out in the sticks, getting about 1.5Mbps, but it's dropped to much longer latency than usual in the last week or so, which I guess is unrelated. (sigh).
11-04-2011 10:38 AM
Quote from: linux I'm curious as to where the "Estimated line speed" actually comes from. At the time it was last "checked", my actual IP profile would have been around 4 or 5 Mb; certainly nowhere near the 1.0Mb quoted above. Where does this figure of 1.0Mb come from, and how was it "checked"?
It's taken from here. It's worth bearing in mind that the results from that particular check are not static and do have a tendency to vary over time.
11-04-2011 10:59 AM
11-04-2011 11:00 AM
Current stats
Quote Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 1.5Mbps; typically the line speed would range between 1Mbps and 3.5Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 2Mbps; typically the line speed would range between 1.5Mbps and 4Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 500Kbps and downstream line speed of 500Kbps; typically the downstream speed would range between 250Kbps and 1.5Mbps.
Noise Margin: 5.9 dB
Connection Rate: 4576 Kbps
Line Attenuation: 50.0 dB
Uptime over 2 weeks
Note that the IP profile hasn't dropped below 3,500 ever since I had the noise margin reset after moving to 21CN ADSL1 and getting the BT system glitch sorted out in September/October last year
Also why is the ADSL 2+ Annex-M so appallingly bad
11-04-2011 11:07 AM
11-04-2011 5:29 PM
this is the first time this has appeared.
Postcode:
Phone exchange:
LOCHGELLY
8Mb (Accurate to within +/- 1Mbit) - Checked on 2011-03-17 16:26:14
Current line speed:
7.15 Mb
Don't know why. It was there when i looked at it recently.
12-04-2011 10:33 AM
12-04-2011 5:01 PM
12-04-2011 5:47 PM
I didn't report it when I first saw it because I thought I'd wait and see if the estimated speed would come back - and in any case it's not a big issue for me.
Graham
12-04-2011 6:14 PM
I've changed nothing other than switching my router off for 2 weeks while I was on holiday in the middle of March.
So I await the explanation!
