Estimated Line Speed profile
- Re: Estimated Line Speed profile
27-05-2016 7:48 PM
I wondered how often this is changed?
Phone exchange: CHIEVELEY
Estimated line speed: 1.0Mb
(This may vary between 0.75Mb and 2.5Mb) - Checked on 2016-03-25 17:07:46
Current line speed: 2.4 Mb
Since the check date I've been migrated to CN21 on 27/4, so estimated speed needs updating.
Will this happen automatically?
BT TEST:
1. Best Effort Test: -provides background information.
Download Speed | |
2.01 Mbps |
0 Mbps | 4 Mbps Max Achievable Speed |
Download speedachieved during the test was - 2.01 Mbps For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps. IP Profile for your line is - 2.45 Mbps |
Upload Speed | |
0.68 Mbps |
0 Mbps | 0.83 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 0.68Mbps Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps |
31-05-2016 6:07 PM
31-05-2016 6:36 PM
I don't think the estimated speed recorded really matters, unless perhaps you're arguing about a fault with Plusnet, and you say your broadband should be faster, and they look at the estimate. And then Plusnet would probably look at the current estimate from BTWholesale anyway.
01-06-2016 9:38 AM
The estimate on our site won't change unless you go through the product change journey, It has no impact on the real life speeds you're getting tbh it's better to check estimates at http://dslchecker.bt.com/
01-06-2016 10:29 AM
Thanks; here are results:
ADSL Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Range(Mbps) |
Availability Date |
Left in Jumper |
WBC ADSL 2+ | Up to 1 | -- | 1 to 3.5 | Available | -- | -- | ||
ADSL Max | Up to 1 | -- | 0.75 to 2.5 | Available | -- | -- |
Current Gateway: gateway pcl-bng02.
BT Wholesale speed test:
Download Speed | |
2.61 Mbps |
Download speedachieved during the test was - 2.61 Mbps For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps. IP Profile for your line is - 2.45 Mbps |
Upload Speed | |
0.72 Mbps |
Upload speed achieved during the test was - 0.72Mbps Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps |
So Chris, can PN revise my profile up a tad pse?
01-06-2016 10:33 AM
Your profile is correct on both the BT side and our side. Your line is in sync at 2779, so a profile of 2.45 is right (ours is 2400).
01-06-2016 11:09 AM
Chris, thanks 4 that.
Had wrongly assumed that the 1mb reported had been throttling my d/l speed:
Estimated line speed:1.0Mb
01-06-2016 11:20 AM
No problem. It's the 'current line speed' that shows what profile we currently have for you.
01-06-2016 1:15 PM
Estimated speed should really only be used to set expectations at time of order. Unfortunately it could also be used at a later date to try and excuse a reduction in speed. Plusnet - do you have MSR and FTR recorded for this line?
01-06-2016 1:21 PM
Yes, this is set during the training period. On this line it's 2278.
01-06-2016 4:19 PM - edited 01-06-2016 4:30 PM
Is that MSR or FTR?
I should point out at although this figures should be set, that's not always the case. Mine remained 2272/1817 which is the 20CN default for almost all my time at Plusnet, apart from a brief time at 288/288 then even briefer at 3424/2739 before returning to 2272/1817 for the remainder.
01-06-2016 4:28 PM
That's the FTR.
