Estimated Line Speed Disappeared.
buseng12
Why has my estimated line speed disappeared?
It used to show 63 Mb although I am only getting 51 Mb.
Like it is trying to hide the over estimation.
High-speed Broadband
Estimated line speed:
Current line speed:
51 Mb
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Estimated Line Speed Disappeared.
This happens from time to time, it's an issue on our systems as opposed to trying to hide the speed estimate - it should be back for you now - apologies for that.
Chris Pettitt
Cloud Environments Engineer
Terranova667
@buseng I had this when I I had my line fault a couple months back, when the estimate came back my it was cut from 67Mb to 29Mb so i wouldn't be surprised to see your estimate cut when it comes back.
Plusnet Staff
Plusnet Staff
Fixes: 5
That and this is a completely separate issue.
The speed estimate in this case is the same.
Chris Pettitt
