Estiamated connection speed (ADSL ADSL2+) and related download speeds
- Re: Estiamated connection speed (ADSL ADSL2+) and ...
29-01-2010 7:56 PM
The forecast connection rate under ADSK2+ is given as 9000. What I am interested to know is whether the average download rate is likely to increase proportionately to the increase in connection speed or would the increase be far less than that, also whether contention has a greater or lesser influence on actual performance under ADSL2+
I await cries of numpty.
Re: Estiamated connection speed (ADSL ADSL2+) and related download speeds
31-01-2010 9:02 AM
31-01-2010 9:22 AM
Try posting some stats from your router, inadequate information otherwise.
31-01-2010 2:31 PM
See attachment.
Edit
Download speed 4930kbps ; Upload speed 375 kbps
31-01-2010 2:45 PM
Could you replace the image by a clearer one, or copy the information from the lower box (connection speeds, attenuations, noise magins) into a post ?
Edit: … as you've done with speedtest results alongside my post, but need information from the router lines.
31-01-2010 3:21 PM
ADSL Link Downstream Upstream
Connection Speed 7424 kbps 448 kbps
Line Attenuation 28.0 db 15.5 db
Noise Margin 11.0 db 24 db
31-01-2010 5:05 PM
31-01-2010 5:14 PM
31-01-2010 6:38 PM
31-01-2010 8:08 PM
NB FWIW Noise margin in day was ca. 6dB
31-01-2010 9:56 PM
You are doing well to get the sync you currently have (7264kbps) on ADSL1, and remain connected down to a Noise Margin of 1dB.
31-01-2010 10:50 PM
Quote What I am interested to know is whether the average download rate is likely to increase proportionately to the increase in connection speed or would the increase be far less than that
Do I take from the above that actual speed %age improvements will not be as great as those for connection speeds?
BTW My Netgear Router has held connection even down to -2dB
01-02-2010 1:27 PM
For a sync speed of 7264kbps your IP Profile - shown by the BT Performance Tester (http://www.speedtester.bt.com/) - should be 6000kbps. The PN Profile should match that, though you mentioned in the Opening Post it showed 5500kbps. The speedtest result you posted (4930kbps) is typical for a 5500kbps profile at off-peak times.
If the ADSL2+ forecast 9000kbps is realised your IP Profile would be 8000kbps, and my expectation is that a throughput (actual speed) of 7000kbps should be achievable at off-peak times.
01-02-2010 4:39 PM
01-02-2010 6:14 PM
I was getting the high conn speed even when PN was showing my profile 5500 :-\how it could happen. But now its at the expected 6000.
Thanks for advice.
Fo you think PN will charge more for ADSL2+?
