Errors
rongtw
Fixes: 12
Errors
ihave read a lot of posts about 585v8 errors  Angry  90% of the time i have a great connection buts its the odd time which always annoys , which error is important and which can i ignore ?
Fixes: 35
Re: Errors
I'd say CRC errors are more worth keeping an eye on, however I won't advocate using those as an indicator of the performance of your connection. I'd judge that on speed and uptime. Given the amount of errors you mention for a 24+hr connection I wouldn't be too concerned.
 Adam Walker
rongtw
Fixes: 12
Re: Errors
Cheers Adam
