Error 550 Relay Not Allowed
- Error 550 Relay Not Allowed
- « Previous
- 1
- 2
- Next »
Re: Error 550 Relay Not Allowed
16-09-2008 6:46 AM
So if you have a paid for account and your partner has a payg account your partner should be able to access authenticated SMTP using your f9 user name and password.
Having explained that I hope that I am not breaking the rules and this gets switched off
16-09-2008 8:52 AM
Quote from: madjbright Having explained that I hope that I am not breaking the rules and this gets switched off
I'd never really suggest giving your username and password to a third party, but we're not going to switch this functionality off or frown upon how you're using your account (unless shed-loads of spam starts originating from it of course!)
22-09-2008 6:50 PM
"Important Note: If you are connecting to the Internet from a different location, you won't be able to use the PlusNet outgoing server. Instead you will need to send your emails using the outgoing server provided by the ISP on which you are connecting. "
Is authenticated SMTP supposed to be a secret?
22-09-2008 6:54 PM
30-09-2008 4:34 PM
Quote from: puddy It will not work with a payg account
Have just done it over GPRS with a Vodafone PAYG account. Can send email using authenticated SMTP
Can also get emails using IMAP (or POP3).
30-09-2008 11:17 PM
01-10-2008 8:37 AM
01-10-2008 9:05 AM
Sounds reasonable, but to me it is an invaluable facility. I hope no one considers turning it off. It would only be a risk if someone's username and password were discovered and then that person would have a whole bunch of trouble with their account.
01-10-2008 9:19 PM
- « Previous
- 1
- 2
- Next »
