Err Connection Timed Out error on my two blogs
- Err Connection Timed Out error on my two blogs
22-03-2018 4:15 PM
Hi all,
I am getting the err connection timed out error when i try to access my two blogs, both hosted on wordpress. I hunted on google and spent about 5 hours (i am not great with computer jargon) doing everything that all the sites listed at possible solutions.
I spoke to Go Daddy and they said they could access it fine. I tried my phone and had the same error but when i turned off the wifi it worked fine pin pointing it to me as a plusnet issue.
So among the solutions i have tried is changing the DNS to 8.8.8.8 etc, changing my LAN settings, unticking protocol 4 boxes, rebooting the router, leaving it off for about 2 hours first time and about 9 hours the second time.
Tried diff browsers etc, all the suggestions.
I just tried ringing but it's 20 min wait time so thought I would post here.
Oh, someone messaged me on facebook asking if i had stopped the blogging as they couldn't access the site, i said no and told him to use his phone 4g and he said it worked. I asked if he was on plusnet and he said yes so it's a plusnet issue for sure.
Anyone have any other ideas or how I can get this looked in to?
The two sites are www.elitemilitaryforces.com and www.tradingthetennis.com
Thanks all, I will try and answer any questions but please remember I am not very technical with computers!
Cheers
Re: Err Connection Timed Out error on my two blogs
23-03-2018 6:25 PM
What router are you using?
I suspect it's the same issue as: https://community.plus.net/t5/Broadband/One-website-will-not-load/td-p/1523332
23-03-2018 6:41 PM
It's a Hub One router. We have had it for over a year but the problem only started maybe 10 days ago.
23-03-2018 7:23 PM
The IP address is slightly different, but it's in the same range (160.153.137.x) as the ones in the other thread.
23-03-2018 7:40 PM
What does that suggest? Do I need a new router? Is there some options I can work through to find a fix? I am not massively technical though lol,
Cheers for your replies so far.
23-03-2018 8:23 PM
Initially I suspected it was a problem with my router, which is a rather old Netgear. But now that I've seen that it is affecting a few people, with different routers, then it's not a problem with anyone's router.
This requires some Plusnet staff input, I don't think there's anything you can do to fix it on your end.
25-03-2018 2:04 PM
@ejs have you had any information at all from Plusnet staff? I can't get through, or when I do they just suggest turning router on and off to gain new IP address. However the problem is obviously with a wider issue than just me and my home network but nobody will acknowledge them. Incredibly frustrating.
25-03-2018 3:50 PM
No, but then I wasn't going to attempt to contact them personally, since the issue doesn't affect any websites I need to use. I am going to continue to wait for someone from Plusnet to read these forums, or for the problem to disappear by itself, whichever comes first. It's not like I have some special codeword to get straight through to some suitably technical department at Plusnet or anything.
