Engineer visit charging question
Lugal
Can I be charged for an engineer visit if the problem is traced to the Plusnet-supplied router - a Sagemcom 2704N?
Fixes: 231
Re: Engineer visit charging question
If you're still within your contract then you wouldn't be charged.
 Matthew Wheeler
Lugal
Thank you.
sharoncook
So if your not in contract and its Plusnet router you can be charged even if the engineer states that you will not as not any router worked until the engineer went to the local exchange and suddenly it worked /
Fixes: 167
If the engineer fixed something at the exchange and that fixed the fault, then you wouldn't get charged for this as the engineers notes should show that the fault was external.
 Chris Parr
 Plusnet Staff
sharoncook
Thanks Chris but the engineer did not mention this on his notes not that I have seen them as I have to pay £10.00 for the priveledge.
Fixes: 167
We should be putting them on to the fault ticket, there's no charge to see the notes from an engineer visit. There is a £10 charge for us providing copies of a phone call based on a subject access request, is this what you asked for?
 Chris Parr
 Plusnet Staff
