Engineer just fitted fibre - will 15Mbps download speed improve?
- Engineer just fitted fibre - will 15Mbps download ...
11-06-2014 9:54 AM
(I tested using the BT Wholesale Performance Test).
Re: Engineer just fitted fibre - will 15Mbps download speed improve?
11-06-2014 10:09 AM
11-06-2014 10:12 AM
Glad to see you're upgrading to Fibre! At the moment we are waiting for the order to reflect as complete as the engineer has very recently attended to complete the work. The speeds should improve once the order completes. You'll be on an open profile for the first 2 days so I'd advise to leave it for the next couple days and see how you get on.
Give us a shout if you think something's not quite right though
11-06-2014 10:17 AM
Quote from: dvorak what does the portal say here https://portal.plus.net/my.html?action=data_transfer_speed ?
15.6.
Linn,
Many thanks, I'll see how it goes over the next couple of days.
11-06-2014 10:20 AM
11-06-2014 10:24 AM
11-06-2014 10:27 AM
11-06-2014 10:32 AM
True, but ain't going to happen until BTOR marks the install as complete.
Kevin
13-06-2014 8:26 PM
Download speed reached circa 50Mps after a few hours and is now 49 according to the PllusNet portal referred to above. But it's around 40 (and 12 upload) according to two other online speed tests and 43/19 according to Ookla.. I rebooted the router tonight (pulled the mains lead out, counted 30 seconds and put it back in) but that hasn't changed anything. What can be done to get anything near the purported available speed?
Another issue is that the PlusNet router conks out a couple of times a day, or the line does, or something does. I never had this before. Is it a feature of fibre?
14-06-2014 9:15 AM
Ookla: 49/19
PlusNet Portal: 62
14-06-2014 10:51 AM
14-06-2014 12:06 PM
From the PC to which my router and modem are attached.
14-06-2014 2:16 PM
When the test completes scroll down to the BBCode (for forums; not supported on thinkbroadband forums) Displaying Graphs and copy/paste that in your reply.
14-06-2014 5:09 PM
14-06-2014 7:21 PM
What does a BT diagnostic speed test say for your latency?
