Emergency Broadband Network Maintenance - 19th November, latency fallout
The only one affected going by the community graphs.  No lost sync or PPP as I have been online the whole time, but my latency has gone from 40ms too 60ms, even after a gateway hop.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Emergency Broadband Network Maintenance - 19th November, latency fallout
From that graph your latency increases started before the maintenance and as you're the only one affected it's very unlikely to be the maintenance causing this. There was a PPP drop shortly before this post, is the latency still the same now?
 Chris Parr
 Plusnet Staff
Chris it increased a bit more after the gateway hop, currently at 60ms
Plusnet Staff
Plusnet Staff
Fixes: 159
I was going to suggest that maybe interleaving was turned on, but that's been on for a while from the DLM data I can see. Would you be able to try another gateway hop, just out of curiosity.
 Chris Parr
 Plusnet Staff
still the same after a second hop from pcl-ag06 too ptw-ag01
