Email delays
- Email delays
Email delays
15-12-2008 1:16 PM
Any one else having delays in receiving their emails?...
Message 1 of 7
(1,347 Views)
6 REPLIES 6
Re: Email delays
15-12-2008 1:21 PM
Not for me.
I've just sent an email from my webmail account to my work account, which arrived almost immediately. I then replied to that email and it turned up in webmail again almost straight away.
Message 2 of 7
(560 Views)
Re: Email delays
15-12-2008 2:36 PM
I sent two emails from yahoo.
One to my main domain (hosted through JTN which will try to forward it to the plusnet servers) ... it has not arrived
One directly to my plusnet domain (xxxx.plus.net) as I run my own server and use SMTP forwarding and it arrived in seconds.
Message 3 of 7
(560 Views)
Re: Email delays
15-12-2008 2:48 PM
Yep, there's a reason on the delays in JTN --> http://servicestatus.net/
I'm not sure whether or not "username" is using JTn. I'd thought not (although happy to be proved wrong!).
Message 4 of 7
(560 Views)
Re: Email delays
15-12-2008 3:17 PM
For some reason the Service Status feed in Thunderbird had dropped its updates
Thanks for that James 😉
Message 5 of 7
(560 Views)
Re: Email delays
17-12-2008 10:33 AM
Quote from: Jameseh Yep, there's a reason on the delays in JTN --> http://servicestatus.net/
Thank you - that was the reason. Your correct we don't user JTN, but our client is!
Message 6 of 7
(560 Views)
Re: Email delays
17-12-2008 10:35 AM
It should all be sorted now anyway so hopefully the emails are arriving in good time.
Message 7 of 7
(560 Views)
