Electrician cut broadband line
MrEkeis
Hello,
I had an electrician working and he cut the broadband line. He reconnected it but broadband is not working anymore. Plusnet are saying an Openreach engineer needs to come out and gave 2 days estimate. We currently have some people over and we all work from home even during weekends.
Is there a way of fixing this asap even if it costs ?
9 REPLIES 9
Fixes: 558
Re: Electrician cut broadband line
Sorry, it's a residential connection and Openreach's SLA is a min 2 day response. If you need better than that then you need a business connection with Enhanced care
MrEkeis
Hi MisterW, thank you.
Shall I bother with getting someone private to fix it ? Or it has to be openreach engineer ?
Fixes: 558
It depends where the cut is. If it's upstream of the Openreach master socket then only Openreach are allowed to work on it. Anything downstream of the ms i.e in your property , is your responsibility
redsox9
Fixes: 4
@MrEkeis
Google for "exBT engineer near me". They might be able to help.
MrEkeis
Thank you.
Trying to get someone to come to have a look. The electrician’s boss is saying the provider needs to activate it from their end, there shouldn’t be a visit or a need for an engineer or the delay.
Plusnet insisted that an openreach engineer needs to come out.
Fixes: 558
Complete rubbish!. If it was working before it was cut, then if its reconnected properly then it will work. It doesnt need re-activating...
lahbrannan1
Fixes: 4
Hi @MisterW
Thank you for your recent message. You are absolutely right, once the service has been activated it does not need reactivationg nevertheless the fault will need to be rectified before the service resumes.
We will be in contact once we receive further updates, apologies for the ongoing inconvenience.
Lee
Lee Brannan
Fixes: 558
@lahbrannan1 just to clarify, its not me with the problem, its @MrEkeis
lahbrannan1
Fixes: 4
Ah, apologies. Typo error on my part
Lee Brannan
