Effect of Firefox upgrade
Fixes: 61
Firefox just upgraded to version 14.0.1 and I immediately noticed that sites were opening much quicker.
Does anyone else see this or is it a coincidence
Fixes: 127
Re: Effect of Firefox upgrade
just gone from 10 to 14 and it does seem a bit snappier.
Will Moderate For Thanks
rongtw
Fixes: 12
Yes Jim its better for me too  Cool
Fixes: 46
Hadn't really noticed loading faster. Certainly not slower though.
David
SpencerUk
@Oldjim
I went from 9 to Waterfox 13..Performance improved 10 fold!.
Assuming you have a 64bit cpu you should try Waterfox Smiley http://waterfoxproject.org/
Fixes: 51
Thanks Spencer, I'm giving it a try. Smiley
Customer and Forum Moderator.
rongtw
Fixes: 12
Spencer  Wink waterfox is cool  Cool
Fixes: 127
and windows only. pft.
Fixes: 16
Fedora Linux users already get a 64bit version supplied by the distribution.
Linux users could fairly easily compile their own copy of Firefox specifying whatever compiler optimizations they want, but it's really not worth it.
Reading the Waterfox FAQ, it's probably best on Intel CPUs.
rongtw
Fixes: 12
1 problem  Sad you cant launch BF3 from a 64bit borwser  Huh
SpencerUk
@rongtw
That isn't down to the browser, that's because the Battleblog plugin is 32bit only.
Because I point blank refuse to use Chrome or IE at home, I use Pale Moon 32bit (http://www.palemoon.org/) just for the Battleblog browser and Waterfox for everything else.
rongtw
Fixes: 12
Cheers Spencer  Wink thanks for the  tip  Cool
PS i hate IE and chrome
