Early Activation
joshlewandowski
Early Activation
Hi, Is there any way I can get activated early? I have seen a couple of posts and it seems do-able if the broadband light is green, I have tried phoning but cant get through, any help would be great, cheers, Josh
Fixes: 68
Re: Early Activation
Hi  joshlewandowski,
I can see you've spoken to someone about 5 minutes after posting.
Hope the connection is working fine for you.
 Adam Walker
seatac
Sorry to hijack. Have the same situation, router is showing all green. Can someone please check if my line has been activated?
Graham
Fixes: 5
You're accounts not showing as live on the BT side. As long as you are aware you will be billed from today and that we can't raise faults (should we need to) until the official completion date, I'd be happy to enable the account for you now.
 Tony T
seatac
Hi Tony
thanks for looking at this and yes, please action ASAP
Cheers
Graham
Fixes: 5
The account's been activated. If you aren't using one of our routers, remember you'll need the realm at the end of the username ( normally @plusdsl.net). If you are using one of our routers, TR69 should automatically set everything up for you.
 Tony T
seatac
Thanks Tony
