Early Activation no longer possible?
- Early Activation no longer possible?
06-09-2013 1:38 PM
I rang up customer services to ask if my account credentials can be activated at my own risk (per http://community.plus.net/forum/index.php/topic,98641.msg834755.html#msg834755 ), as my router appears to be syncing. I was told that my order is showing as completed by BT but not closed, and that plusnet are unable to activate me until they have closed it, which will not happen until my activation date. I was also told that although my router is syncing, there will be no ADSL signal on the line until my activation date.
I'm a little confused, to say the least
Message 1 of 4
(664 Views)
3 REPLIES 3
Re: Early Activation no longer possible?
06-09-2013 1:52 PM
Sorry about the response you had there it isn't right!
I'll get the account activated now and I'll get some feedback passed on to the person you spoke with. The only effect this actually has on us is that we'd be unable to raise a fault with our suppliers if any issues ocurred with the line/exchange etc between now and the originally proposed connection date.
Adam
Adam
Message 2 of 4
(398 Views)
06-09-2013 2:06 PM
Thank you very much, my connection works now!
Internet withdrawal is surprisingly painful... *sighs in relief*
Message 3 of 4
(398 Views)
06-09-2013 2:09 PM
Message 4 of 4
(398 Views)
