EXPERT NEEDED : Broadband Download at 0.22mbps this is terrible.
- EXPERT NEEDED : Broadband Download at 0.22mbps thi...
21-05-2018 1:51 AM
Well, i think the title of the thread says it all. Now TV, Nope not working, XBox, Nope, Youtube, Yeah if you like to watch bufferring. Any help available at all please. Ive had a new router delivered and still terrible.
Re: EXPERT NEEDED : Broadband Download at 0.22mbps this is terrible.
21-05-2018 9:32 AM
If the line is unstable, or if you're having any noise or issues with the phone line then you may have an underlying problem, and you be best running the home check-in this case plug your system into the test socket and see whether this helps. Otherwise again call support for line tests etc.
21-05-2018 12:42 PM - edited 21-05-2018 12:43 PM
What d/load speed were you promised during sign up?
Follow self help links below. Is the phone line clear of any crackles etc.?
If that's noisy, the BB that runs on it will falter.
23-05-2018 5:01 PM
25-05-2018 12:02 PM
25-05-2018 12:09 PM - edited 25-05-2018 12:10 PM
You can find your support tickets here https://www.plus.net/wizard/?p=search
Log into the portal required.
