ERR_CONNECTION_TIMED_OUT with BoyleSports
ianshaircut
I can't find an ongoing thread for ERR_CONNECTION_TIMED_OUT otherwise I'd have added it there. Whenever I go to http://www.boylesports.com/ I get the connection timeout. This happens with a wired PC and my phone over WiFi. My wireless MAC also won't connect. If I disconnect my phone from WiFi and use the mobile signal I can access the site, possibly suggesting it's a problem with the broadband rather than my PC. Either way, I've tried flushing DNS and renewing ipconfig but that hasn't helped. What else can I try?
Fixes: 161
Re: ERR_CONNECTION_TIMED_OUT with BoyleSports
Can you carry out a traceroute and paste the results here?
If you're unsure on how to do this there are instructions here
[edit]
We've made some changes which may have fixed this.
Can you try accessing it again?
 Matthew Wheeler
ianshaircut
I'd just noticed it was working when I tried to traceroute. It seems to be working again, but I did get
"11 * * * Request timed out."
for 1 or the 12 stages. I don't know if that's normal or not. Possibly problem solved. Thanks for your help.
Fixes: 161
Glad to hear it's working.
 Matthew Wheeler
