E mail from plusnet today
- E mail from plusnet today
- « Previous
- 1
- 2
- Next »
Re: E mail from plusnet today
04-03-2011 5:07 PM
I've asked one of our faults guys to pick this up for you.
Jojo
04-03-2011 5:46 PM
Jojo thank you.
Jelv I have taken your comments on board, and as valid as they probably are, you are taking the standpoint of someone who is 'in the know' I have had a very fast learning curve as far as plusnet is concerned.
I would not normally expect to have to delve into the statistics of a router, find out the BT speed test, and whatever else, and publish the results, I fully understand that some feedback from the customer is a requirement for fault testing, but the onus seems to be put on the customer for a resolve rather than the supplier.
04-03-2011 6:51 PM
04-03-2011 8:09 PM
Thanks for your response, I appreciate that plusnet do endeavour to avoid customers facing an exorbitant bill from BT, but I do have some issues with the internal wiring scenario, there may well be instances of people hard wiring extensions with bits of bell-wire connected with terminal blocks wrapped in insulating tape, there may also be those that are incapable of simply following instructions on where, and how to plug leads in, as I have already stated, my router is directly connected to the BT test socket with the cable supplied by plusnet, my computer is likewise connected to the router with the cable supplied by plusnet, I have already stated that one of the two filters supplied was faulty (no throughput connection on the data side), fortunately the other filter proved to be Ok. The main BT socket is brand new and was installed and tested along with the line on the 10th of Feb 2011, in the light of all this I will be assuming absolutely no responsibility for any fault with the internal wiring, it's what I received with the router.
To be fair, I am not laying any blame with plusnet, I believe that there may well be an issue with the existing external cabling which is frankly ancient, or that something has gone awry at the exchange.
Best regards
08-03-2011 8:21 AM
A quick update,
BT engineers visit yesterday and find a fault on the line, off they go to fix the fault on the line, they report back an hour later that the problem is sorted and that 7Mb/s was found at the cabinet, he checks my main box and finds 6.5Mb/s! wonderful!
I connect to the net and do a speed test, all three of us are watching the speedometer with baited breath and the result is.........0.25Mb/s engineer gets on his mobile, "Ahh mate your line is capped at 0.5Mb/s I have asked for it to come off, it should take 2 hours" Lovely, I thank them both and send them on their way.
Later on that night I take a look at plusnet's site and am pleased to see a line speed of 6.5Mb/s I'm not getting it mind but it least it looks promising, I check again this morning 5.5Mb/s Hmmm, check again 1 hour later 5Mb/s, I start to get that gloom and doom feeling, so do a speed test, what am I actually getting? 0.25 Mb/s download 0.33Mb/s upload. Oh well, par for the course then!
So another ten days of snail surfing while the router is potty trained again, well actually no because I have had to pay for some data allowance on my 3G dongle ( which delivers 3Mb/s all day, every day, without fail) so I can actually do some work.
08-03-2011 8:32 AM
Next you need to check if your line is syncing as fast as it could. To do this you need to look at the stats reported by your router (sync speed, attenuation and noise margin). If you post those here we will help you interpret them.
08-03-2011 10:04 AM
I've identified a consistency issue, which is basically a stuck profile, so although you have a 5000 bRAS profile, the MSAN (the piece of equipment at the exchange that you are connected to) is still giving you the old profile. I have rectified this and reset your line. This can take up to 24 hours to take effect (it's normally a lot quicker) but I believe it's more of a configuration problem rather than a physical one now so it should be sorted soon.
Jojo
08-03-2011 10:05 AM
Just as I was about to respond my router re-set itself I have attached the results
08-03-2011 10:07 AM
john
08-03-2011 10:17 AM
- « Previous
- 1
- 2
- Next »
