E mail from plusnet today
bluehoadley
I have just received this e mail from plusnet support
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 3Mbps
Current line speed: 0.25Mbps
You can keep a track of your line speed through our website:
To find out more about how broadband works, and the things that can affect the speed of your service, we've written an article all about high-speed broadband:
http://www.plus.net/support/broadband/speed_guide/high-speed.shtml
If you've got any questions about your service our Community Forums have loads of information and help available ( http://community.plus.net/forum/ ). You can contact us online using the Help Assistant ( http://support.plus.net/ ) or you can call us on 0845 1400200.
Kind regards,
Plusnet Customer Support
This is my current speed
Router is the standard Thomson with upgraded firmware plugged directly into the BT test socket, no extension leads.
I managed to get  25 Mb/s once in the 14 days I have been connected, most of the time the speed is a constant 0.13 Mb/s I have a ticket No 40028326 which is apparently awaiting customer response ie feedback on my current speed, well plusnet you already have it, look at your e mail. I will go back to customer support and report my findings, in the meanwhile if there a re any plusnet staff on the forum I would appreciate an investigation. Attached below is the result of the BT speed test, and my router stats.
Fixes: 10
Re: E mail from plusnet today
When you use the telephone is the line clear with no background noise? (You can use the quiet line test to check: dial 17070 and take option 2)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bluehoadley
Ok tried that, there is a very small amount of  background hiss that fades out within a second or so.
adie:quote
Fixes: 10
That's different! I wouldn't rule it it out as being connected to your problems.
Is your phone a wired phone or a cordless (DECT) phone? Some DECT phones give problems and people have found double filtering them beneficial.
bluehoadley
It's a DECT phone, I have just tried the connection with the phone removed from the line and powered off, the speed test result is:
Virtually the same!
Fixes: 62
can you connect the router to the test socket with nothing else connected and report the stats
bluehoadley
Ok,
Router plugged directly into Bt test socket
Router stats attached
Fixes: 10
Shocked Those stats are terrible.
You need to raise a fault if you haven't already done so: http://faults.plus.net/
Fixes: 62
Those stats show you have been connected at the test socket for nearly 6 hours.
Given that the time then would have been about 5.00 a.m. was it moved last night and had a resync at that time or did you actually move it then.
We don't need speed test results as they are limited by the IP profile
bluehoadley
I turned the router off briefly at that time in an effort to see if a reconnection would improve the speed any, I was trying to get on to a forum I belong to and the page load time was ridiculous, I just lost patience with it.
Fixes: 10
Have you tried a different router and/or filter?
bluehoadley
I  tried a D-Link DSL-G624T about a week ago with no significant improvement, I have tried about six different filters none of which make a difference (one of the plusnet ones was duff from the start)  Angry
Fixes: 62
As Jelv said - you need to raise a fault
bluehoadley
I have an ongoing ticket which I have updated so I suppose it's a case of wait for the response,
thanks for the help gentlemen
Fixes: 10
Quote from: FiftyFive
If your check that changing anything had made an improvement was to run a speed test you wasted your time and proved absolutely nothing!
You need to compare the stats reported by the router to see if the sync speed has improved or the noise margin has changed.
Because of the way the BT DLM system works it may be several DAYS before an improved sync speed is reflected in better speed test results.
Edit: If you changed a number of things in a short period you may have actually made things worse!
