Hi, I am having an issue with Dynamic DNS. I can get it to work with either DTNS or DYNDNS, initially it works OK but it does not automatically reconnect when the router is restarted.
If I log back into the router and check the dyanmic DNS page is shows "Update required" after the hostname. If I open and save the configuration it updates to say update successful. I do not need to make any changes just open and save the configuration.
Any help would be welcome as this router is a 3 hour drive away and I really need the dynamic DNS to be reliable and reset OK after a power cycle.
