Dropping connection
- Dropping connection
- « Previous
- 1
- 2
- Next »
Re: Dropping connection
17-11-2016 2:31 PM
That's not so good, I only suggested as I had the same issue as you were describing and this was the fix for me at least. Mind you whether it's relevant my Ethernet is connected to a managed switch that allows me to set the duplex and flow control for each port, and was done to match the value set on my Ethernet card.
17-11-2016 2:38 PM
@Anonymous
Thank you for help.
Could I ask, what is a managed switch? I'm not that technical so know little beyond plug n play!
I went through 'system preferences - network - advanced - hardware' to find the screen which you showed on your earlier post to change my settings
17-11-2016 2:50 PM
You're welcome @DerbyLad nothing ventured nothing gained, and when you said you had a Mac I thought it sounded so much like the issue I had that it might be a fix for yourself.
As to what a managed switch is then this article should give you an idea as to what they're about, but for the majority of users are overkill.
Also, the steps you took are correct as that is where I got the screen capture from and since it didn't work you can of course revert back to your previous settings, assuming you made a note of them.
18-11-2016 1:24 PM
Please comment on what I should do next?
Do you have any suggestions to resolve my issue?
Am I entitled to a replacement router from Plusnet?
18-11-2016 1:29 PM
Have you tried an alternative device, just in case it's your Mac? (Hopefully not)
18-11-2016 1:31 PM
Yes, I have also tried a PC running windows 10 and I had the same issue
18-11-2016 1:33 PM
If your router is less than 12 months old I'll be happy to RMA it as it does appear that it may be faulty. I'm not in the office at the moment, but I'll take a look at your account tomorrow.
18-11-2016 1:35 PM
Thank you. I shall look forward to hearing from you
19-11-2016 2:16 PM - edited 20-11-2016 10:36 AM
@DerbyLad I'm unable to locate your account from your forum username. Please can you private message me your account username?
[Edit]
Thanks for your PM @DerbyLad Your router is out of warranty so I wouldn't be able to RMA it I'm afra
I'll be happy to give you a call to discuss your options. Alternatively, you can call us our customer options team on 0800 013 2632 (Selecting option 1, then option 2). Open until 6pm today, and back at 8am tomorrow.
- « Previous
- 1
- 2
- Next »
