Dropping connection
DerbyLad
Dropping connection
Hi All,
At least 4 times a day my internet drops connection for a short time.
It varies from what seems 1 minute to 3 or 4 minutes.
Having read other posts I checked my router.
Whilst checking I lost connection, my router went from saying the following on 'Connection Status'
Internet status: Connected
WAN IP Adress: (ip address listed)
Broadband Username: (user name listed)
Wi-Fi Network: (says my wifi network name)
to
Internet status: DSL Down Connected Disconnected Connecting Bridge Not configured
WAN IP Adress:
Broadband Username: Change
Any ideas or suggestions?
Fixes: 181
Re: Dropping connection
As you're on Fibre and using the Hub Zero it will always report the DSL connection as down due to the Hub Zero not having a fibre modem built in.
Your connection actually looks quite stable as shown below. Are you connecting over wired or wireless?
 Matthew Wheeler
DerbyLad
I'm wired.
I have lost connection to the router 3 times this morning that I have noticed.
Also for the 1st time ever, on Saturday or Sunday (I forget which) my mobile phone lost connection and was asking for the password.  When I inputed the wifi password it said it was wrong.  I tried a few times till eventually I gave up and rebooted the router.  After the reboot it connected automatically.
Fixes: 181
What happens when you lose connection?
Do you get a particular error?
 Matthew Wheeler
DerbyLad
I don't get an error message.
The way I know is that web pages will not load, my email programme can't connect and I also notice that my 'Google Drive' sync icon greys out
DerbyLad
Could it be a problem with my router?
Plusnet Staff
Plusnet Staff
Fixes: 116
It's possible. I have seen this before:
It should just show one status, rather than all possible statuses. Have you tried a factory reset?
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
DerbyLad
Hi Anoush,
Today I have done a factory reset, so will see what happens and let you know.
DerbyLad
Ok, I reset the router and I'm still having the same problem.  Is it possible for Plusnet to send me out a new router or do I need to buy one?
Fixes: 31
@DerbyLad - Are you running Windows 10 by any chance?
DerbyLad
Hi Mook,
No, I'm on an iMac running Sierra
Fixes: 31
Ah well @DerbyLad in that case can I suggest you set the Duplex control on your Ethernet card as shown here:
However do not set the Speed or MTU unless you are connected to a switch that supports it and leave it at their defaults.
You may think it's (I'm) bonkers but please try it.
DerbyLad
Hi Mook,
I have made the changes and will monitor and let you know if things improve.
Thank you for your help
milner
I had a very similar problem recently, with the latest Hub One router. It went on for weeks until I got a new one from Plusnet. The problem was solved immediately, as long as my main computer, an iMac, was connected using ethernet. However other portable devices are not working very well using wi fi. I've tried all manner of things including changing the channels but wi fi isn't working as it should, where previously it did.
DerbyLad
Hi @Mook ,
Unfortunately my connection is still dropping Sad
@milner
Looks like I might need a new router too
@Anoush @MatthewWheeler
Do you have any suggestions I could try?
