Dropping Connection
- Re: Dropping Connection
Dropping Connection
07-12-2013 7:43 AM
As mentioned in the past I use wireless connection because of where the main BT socket is located. After changing my PV I had problems with it so bought some Home Plugs and everything has been tickety boo for the 5 months.
Since Thursday I've had a yellow triangle appear on my connection icon and google telling me it can't load pages, when investigated windows tells me I have an incorrect IP profile assigned.
Not really understanding these things would this a problem at my end or further down the line?
Message 1 of 3
(511 Views)
2 REPLIES 2
07-12-2013 8:45 AM
The problem is likely to be at your end.
How long is it since the router was last restarted? What OS are you running? If you run a dos prompt on the PC saving the problem and run 'ipconfig' (without the quotes, what address details are returned?
I have seen situations where the TG582n has difficulty assigning IP addresses after extended use - computers connect to the wifi ok but do not get an IP address. Your problem description sounds similar to this experience. Details from the ipconfig command will indicate if this is your Robles.
Message 2 of 3
(321 Views)
08-12-2013 8:59 AM
Hi Townman thanks for your help -
I did a disconnect and recon through the router home page and it was fine last night but back to square one today - I'm using Windows 7 professional and the router is a Belkin Surf 300 the home plugs are Devolo. To be honest whilst I am normally OK with operating and looking after my pc's some of the 'backgorund' stuff for the web I don't understand.
Is this what you asked for?
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Wireless LAN adapter Wireless Network Connection 2:
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Belkin
Link-local IPv6 Address . . . . . : fe80::2908:ecff:d8eb:f4b5%13
IPv4 Address. . . . . . . . . . . : 192.168.2.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.2.1
Ethernet adapter Local Area Connection:
Tunnel adapter isatap.Belkin:
Tunnel adapter Local Area Connection* 11:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:ec:3a21:3f57:fdfc
Link-local IPv6 Address . . . . . : fe80::ec:3a21:3f57:fdfc%15
Default Gateway . . . . . . . . . : ::
Message 3 of 3
(321 Views)
