Drop in sync speed
- Drop in sync speed
Drop in sync speed
15-09-2011 11:58 AM
Re: Drop in sync speed
15-09-2011 12:50 PM
15-09-2011 3:19 PM
not sure why you can't get a higher sync, it's not like a high SNR is keeping it down. Maybe worth trying a different filter.
Jojo
15-09-2011 3:37 PM
15-09-2011 4:02 PM
I'll try an SNR reset and see if it kicks something.
Jojo
15-09-2011 4:03 PM
15-09-2011 4:23 PM
System Up Time 00:06:05
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 1926 2214 0 8439 13515 00:03:05
LAN 10M/100M 3078 0 0 2628 0 00:06:01
ADSL Link Downstream Upstream
Connection Speed 2944 kbps 448 kbps
Line Attenuation 45.0 db 27.0 db
Noise Margin 6.6 db 22.0 db
15-09-2011 4:25 PM
I know it's frustrating but try not to be impatient and don't keep rebooting it, otherwise I won't know if the SNR reset has worked.
Jojo
15-09-2011 4:27 PM
15-09-2011 4:34 PM
15-09-2011 4:46 PM
16-09-2011 12:14 PM
System Up Time 19:55:30
WAN PPPoA 1704968 2615414 0 3380 51817 13:41:23
LAN 10M/100M 242878 0 0 757 0 19:55:26
Connection Speed 2176 kbps 448 kbps
Noise Margin 10.0 db 22.0 db
16-09-2011 12:17 PM
Don't think a reboot will help, but it's up to you. Does seem like the electrician might have inadvertently disturbed something.
Jojo
16-09-2011 1:26 PM
16-09-2011 3:58 PM
I'll do it again as I think your rebooting may have interfered with the process, but please do not reboot, any changes from this end will force one for you.
Jojo
