Drop in sync rate
- Drop in sync rate
Drop in sync rate
20-12-2009 4:36 PM
Today I was reconnected at a sync rate of 3023 and I'm trying to work out why this might have happen and if there is any way to get my speed improved.
On 6th December I replaced the faceplate on my BT socket with one from ADSL Nation. Immediately after doing this I got the following stats:
Sync: 3023
Attenuation: 50.5
Noise Margin: 11.8.
BT profile: 2000
I asked for my Plus net IP profile to reset (it had been 1750) and Rami told me that I was on a banded profile but that "ILQ has just been changed to green" so my connection was likely to improve.
A few days later my IP profile increased to 2500.
On 12th December was reconnected with the following stats:
4544 kbps
Noise Margin: 11.9 db.
IP profile 4000
According to Rami this is due to my banding being increased to the next level up.
A couple more days and the noise margin dropped to about 6 and a few days later increased itself back up again.
This morning, I had been connected for at least 80 hours on a seemingly stable connection when I was dropped back to a sync of 3023, this time with SNR margin of about 17. I guess this means my band was lowered again? Why would this happen when I had a seemingly stable connection?
Any insight would be appreciated.
Thanks,
Jonathan
I've grabbed the stats from my netgear router but I don't know what I should expect them to be. Pasted below.
Uptime 1189251.19 1188702.93
Wan up 1187562.90 1187020.16
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 1
Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 3023 Kbps
Link Power State: L0
Mode: ADSL2+
Channel: Fast
Trellis: U:OFF /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 17.1 18.3
Attn(dB): 50.5 26.7
Pwr(dBm): 19.1 11.7
Max(Kbps): 7028 17899
Rate (Kbps): 3023 448
G.dmt framing
K: 47(0) 57
R: 16 0
S: 1 1
D: 64 1
ADSL2 framing
MSGc: 60 14
B: 46 56
M: 1 1
T: 2 1
R: 16 0
S: 0.4921 4.0000
L: 1024 114
D: 64 1
Counters
SF: 1611437 1308665
SFErr: 10 4442
RS: 212709802 0
RSCorr: 1576 14334
RSUnCorr: 157 0
HEC: 9 2388
OCD: 1 0
LCD: 0 0
Total Cells: 186623234 3758860559
Data Cells: 1161160 25055133
Drop Cells: 0
Bit Errors: 0 181067
ES: 5327 1763
SES: 258 50
UAS: 80 755823
AS: 26174
INP: 4.00 0.00
PER: 16.24 20.00
delay: 7.87 1.00
OR: 32.50 8.00
Bitswap: 0 7618
Total time = 1 days 18 hours 20 min 51 sec
SF = 73184557
CRC = 20277
LOS = 3
LOF = 26
ES = 5327
Latest 1 day time = 18 hours 20 min 51 sec
SF = 4063756
CRC = 590
LOS = 1
LOF = 9
ES = 117
Latest 15 minutes time = 5 min 51 sec
SF = 21613
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 55454
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 24 hours 0 sec
SF = 5316888
CRC = 10925
LOS = 0
LOF = 0
ES = 1720
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 55392
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 55393
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 55392
CRC = 0
LOS = 0
LOF = 0
ES = 0
Sync: 3023
Attenuation: 50.5
Noise Margin: 11.8.
BT profile: 2000
4544 kbps
IP profile 4000
Thanks,
Jonathan
Mode: ADSL2+
Channel: Fast
Down Up
SNR (dB): 17.1 18.3
Attn(dB): 50.5 26.7
Pwr(dBm): 19.1 11.7
G.dmt framing
K: 47(0) 57
R: 16 0
S: 1 1
D: 64 1
ADSL2 framing
MSGc: 60 14
B: 46 56
M: 1 1
T: 2 1
R: 16 0
S: 0.4921 4.0000
L: 1024 114
D: 64 1
Counters
SF: 1611437 1308665
SFErr: 10 4442
RS: 212709802 0
RSCorr: 1576 14334
RSUnCorr: 157 0
HEC: 9 2388
OCD: 1 0
LCD: 0 0
Drop Cells: 0
ES: 5327 1763
SES: 258 50
UAS: 80 755823
AS: 26174
INP: 4.00 0.00
PER: 16.24 20.00
delay: 7.87 1.00
OR: 32.50 8.00
Bitswap: 0 7618
SF = 73184557
CRC = 20277
LOS = 3
LOF = 26
ES = 5327
SF = 4063756
CRC = 590
LOS = 1
LOF = 9
ES = 117
SF = 21613
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 55454
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 5316888
CRC = 10925
LOS = 0
LOF = 0
ES = 1720
SF = 55392
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 55393
CRC = 0
LOS = 0
LOF = 0
ES = 0
SF = 55392
CRC = 0
LOS = 0
LOF = 0
ES = 0
Message 1 of 1
(727 Views)
